Question about Whirlpool GEW9250 Electric Dryer
Fly in door
I have a fly in the door and I want to know the easiest way to get it out.
    Novelist:
  • 131 Answers
There's about 12 Phillips screws holding the inside of the door together. You do not need to remove the door from the hinges. Remove the screws and pull the inner panel away from the outer panel. When re-installing, be careful you do not over-tighten these screws.
Atogether, It's pretty simple, but there's a plastic insert opposite the hinge that sometimes refuses to be aligned properly when you put it back together. If this happens, the insert can catch on the plastic strip that covers the unused holes for switching the hinge to the other side. Worst case - remove the plastic strip if this becomes an issue.
Posted on Mar 10, 2008
Washer belt 7 PJE 1303
Right size belt, just a bear to put on. Easiest way, zip tie belt to fly wheel (one each side of spoke/spine). Than run belt around pulley on motor, turn fly wheel, helps to guide belt as you turn. Takes a lil force but not much. Than slowly turn fly wheel to center belt. Be sure the ribs of belt are in troffs of pulley, if not easily pushed over, about 1 inch from pulley.
Jun 25, 2012 | General Washing Machines
My b/f has a 1990 Fleetwood Cadillac...He believes the fly wheel may be broken...Where is the fly wheel and are they easy to replace?
Flywheel is between the motor and transmission the starter actually runs the flywheel to start the motor. To change it you will have to pull the transmission away from the motor to get to the bolts that hold it to the motor. Not the easiest thing to replace by any means.
Jan 05, 2011 | 1990 Cadillac Fleetwood
Cltuch 97 excel
dont listen to them, easiest way is: remove air intake box(3 nuts)
remove nuts surrounding the outer gearbox(about 6) and then remove the gearbox mounts
lower the gearbox and move slightly to the drivers-side. best to put a block or jack under it. then take the fly-wheel off(marking where it sits against the clutch kit)
and then pull the clutch plate off, making sure all fingers are not bent. i picked up a full clutch kit 2nd hand for 25$
Nov 14, 2009 | 1990 Hyundai Excel
1995 Dodge Dakota> Removing door panel. Can't remove Window knob.. have to replace locks(both sides)....easiest steps to replacing the locks??
Their are two options on removing the door crank-one the base of the crank top comes off where it is connected to the panel and if you pry slight with a thin tool it will expose where you can remove with either a torx or a nut driver-second option you must slip in door panel clip removal tool to relase the spring clip-these fly if you don't keep be careful. clip tools are at most auto parts store-by slighty spreading the door crank look down and you will see spring clip.Note it's either nut removal or spring removal.
Sep 17, 2009 | 1995 Dodge Dakota
There are flies inside on the screen. how do i get rid of them
By flies I take it you mean house flies? If so wait untill night, turn off your tv turn on one very bright light in the room by morning they will be out of the TV to rid your home of flies turn off all lights open the front door turn on the porch light (must be bright white) and they will go to the light then just close the door
May 21, 2009 | Hitachi 42V715 Rear Projection Television
Passenger mirror broken
In the UK we cant get a replacement mirror glass. You may find it easier and cheaper to get one from a junk yard and fit it your self they just scew to the door and not too much of a job to do yourself
May 12, 2009 | 1996 Ford Explorer
How do you get to the fly wheel to check magnet. I removed the pully but their is a screen over the fly wheel, how do you remove the screen?
there should be about 3 screws that hold the screen over the flywheel. If you have a compact wrench it is the easiest way to remove the flywheel. Remove the nut and using a fly wheel puller, which can be made with a few screws and a piece of 2" x 4 " metal with drilled holes the exact distance of the flywheel puller holes in your tiller (much cheaper than purcasing one), work the flywheel loose and ta da there is the magnet.
Apr 17, 2009 | Troy-Bilt Garden
The child safety door lock can not unlock.
Please help me ! i can't find "child lock" button on the rear door of Bently continential flying spur ! Now i can't open rear door from inside car :( ! Anybody know ? help me plzzzz ! thanks alot !
Apr 07, 2009 | 2007 Bentley Continental Flying Spur Sedan
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool GEW9250 Electric Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
