Ibm 6400 012 cta serial# 01a3606
The printer is not printing all the way across the paper! it has a new ribbon, the first 10 - 15 characters are not printing. it does print in the middle section, and the last 20 or so characters are not printing??? what can cause this?? the shuttle??
thanks Alan
    New Friend:
  • 159 Answers
Check up the hummer module or the logic board in the shuttle
Posted on Mar 11, 2008
Printing on the top half of the characters
Is your platen snapped down all the way? Can you look at the ribbon and see where the letters are striking the ribbon?
Apr 01, 2014 | IBM Office Equipment & Supplies
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Jan 02, 2014 | IBM Wheelwriter 6 Typewriter
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
Characters do not print.
The print solenoid plunger has a plastic cap on the end of the plunger it is probably broken. They are available but you need a bit of mechanical ability to install.
DickyO
Mar 18, 2009 | IBM Office Equipment & Supplies
Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Jan 23, 2009 | IBM 4247 A00 Matrix Printer
Ribbon has been replaced now won't type
The most likely problem is the plastic cap in the print solenoid plunger is broken they are available but a little tricky to install. The soleniod is round and just inside the l. printer side frame.
DickyO
Oct 30, 2008 | IBM Wheelwriter 30 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
PRINTING ON A BLACK BACK PAPER
DYE YOUR RIBBON WHITE SPORT!
White ink the ribbon, should do the job, never seen anything comercially for it.
Nov 19, 2007 | IBM Infoprint 6500 Matrix Printer
Characters fill in intermittently.
This is a common problem with old supplies stored in a humid environment. Try leaving ribbon in an air conditioned environment for a couple of days to see if it helps. Otherwise buy a new sealed ribbon to try. Also push the hammer buy hand and see if it moves in and out freely and quickly. If not, the hammer needs some lubricant and or adjusting.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
191 people viewed this question
jasbo
jasbo
