Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave erratically starts
My GE Spacemaker starts cooking on its own. The microwave will all of a suddent start up with a beep and cook in veggies mode until the stop button is pressed. The machine will stay off for a while and then start up again. I've pressed cancel lots of times but eventually it starts again.
  • melcooke Mar 14, 2008
    I took unit apart, removed the circuit board behind the touch pad and cleaned all of the oil/grime that had built up with contact cleaner and isopropyl alcohol. I then used a blow dryer set on low to thoroughly dry the unit before re-assembling. The unit appears to be working just fine but I'll keep a close eye on it.
    I'm quite surprised with the amount of oil (?) that had collected and that the manufacturer had not done a better job of sealing the electronic area off from the ventilation ducts. This unit is vented to the outside.
  • GE Master
  • 9,086 Answers
Your keypad is going bad and will have to be replaced. This is not too hard a job for a DIYer, or we do this job for $39.95 plus part cost for customers nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 11, 2008
There is a beep noise every 60 seconds 24 hours/day... what can we do to stop it? microwave model JTP85WOA2WW serial # zv676667q
My microwave beeps once every minute to let me know that it has finished cooking. If I open the door, then close it, the beep stops.
Jul 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When the microwave is finished cooking how can I change the beeping so it only goes off once instead of4 times? That drives me crazy and is so annoying. Thanks, Susan
Hi, you cannot change how the microwave oven beeps after it cooking. You can confirm this by going through the user manual yourself....
May 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker II Microwave won't beep
hi,
The control board may need to be replaced, check your records to see if the unit is still in warranty, if it is call for repair. If it's not and you’re handy, you can find the part online and replace it yourself, just make sure you unplug it before you work on it. Please contact me if you need help.
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave spacemaker xl1800
F-3 means shorted touch panel pad. In order to attempt clearing the code yourself, please follow the steps below:
  1. Press CLEAR/OFF or CANCEL.
  2. Program control again.
  3. If the fault code appears again, disconnect power to the microwave for 30 seconds.
  4. Program the cooking function again.
  5. IF it comes back up you should change out the panel hope that helps, good luck
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Over the Range Microwave/Convection won't start
So it's dead - that is to say no display, no lights, and no response from the keypad?
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
