Question about Maxtor Hard Drive
2nd HDD installed as slave but still unloaded with software
I have been trying to get help since afternoon with no success.
I installed a 2nd HDD after the original hard drive ran out of space even after I had deleted some files. The 2nd (newly installed) HDD was partitioned using Windows XP and the system can detect it during booting.
My problem now is that I can't load anything onto this new hard drive which is installed as a slave.
My OS is Windows XP Home Edition.
Please help before my computer crashes.
  • Technocrat2 Mar 10, 2008
    Ok brother. I installed a 2nd Had drive rated at 120gb. This drive has been as a slave, has been partitioned and formatted.
    The master hard drive contains the Windows XP HE OS and a host of application system and is running at full capacity.
    My problem now is that I can't transfer some of the software from the master hard drive so that I can run the computer with two hard drives.
    How can I achieve this?
  • Cisf May 11, 2010
    give more details ,. i don;t realy understand u;re problem! So the system can see the new disk (also it;s designated letter in u're windows ) but u;re unable to write data on it ?!
  • 176 Answers
So u;re saying that when u try to save what ever u're working on
 the system tells u that it is to full !? This does not mean that
the system does not use both drives (u just didn't tell it what to do with the new one ...) !!!
- well u can try to move u;re work (not the software itself) on the new disk, and so it will free up the old disk (the one with the OS on it)
- u can try to reinstall the software on the new larger partitions on the new drive, and work there.
-but the best ting wold be to reinstall windows and all software on the larger disk (u can first try to just copy all data from u;re current C drive to a larger partition on the new disk (the partition that is set as active (so the system to know to boot from it)) and make this harddrive the primary one ...) (if the new disk is faster than the older drive, than u;re system will work a little faster ...)
- and another thing that u can do is to attach the new drive to the old one, so that the system would see just one big drive (the sum of the old and new one ! ) BUT this is very risky couse' u can lose all u're data if an error ocures, or if one drive dies...
 If i still don't get what u really want ... tell me ...
Posted on Mar 10, 2008
  • 104 Answers
Simple, if your hardware is working all OK do this:
AND DO THIS CUZ WINDOWS XP HOME EDITION lacks of the needed administrative tools.
Go to the net and find PARTITION MAGIG or PARTITION MANAGER... download the windows version of any of those and partition the HD with them.
2. PARTITION MUST BE NTFS (Windows XP version) that you will see in Partition Magic options...
3. If you format from Windows, disk must be intitialized as BASIC type.
if you do this and you suceed the HD will work, if not, it has a problem, either logical or physic.
Good Luck
I have 3Q HDD External, and my usb can not see it everytime, every 5 minutes i can see it everytime...
hallo there, sounds like your usb bus does not have either the needed power to handle the external device and capacitors which provide could be defective, which means they are loading up and then unloading which brings a usb stop up. otherwise check your system configuration for your usb port. power usage can be defined per port on either nix systems as also on M$'s;
other option is the power supply is of cheap make and the hardware inside cant handle the power needs.
1st: check usb port power definitions,
2nd: try other port
3rd: try other power supply
P.S. sounds maybe stupid but have you tried other usb port? some of the ports provide extra power as for un-powered hdd's.
Look in the manual of your handbook as for how much power is supplied by the divers ports.
Mar 30, 2011 | Computers & Internet
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
Aug 04, 2010 | Maxtor Hard Drive
Laptop 2nd HDD(Slave) running max 20mb/s
Why not install a new 2.5" hdd in your laptop caddy.I replaced my 40gb with a 160gb, works fine and the data tranfer speed is better than a slave configuration. The average speed of around 40mb/sec Is because of the smaller platter, the amount of cache, the firmware installed and so on.
Apr 09, 2010 | Fujitsu Computers & Internet
Insatlling 2nd HDD
The drive is bad, I had a similar problem with a WD HDD, You can download Seatools and work on it in DOS,
Apr 29, 2009 | ASUS P4S533-MX Motherboard
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Strapping or Jumpering for slave
You need the system info for the laptop you are using to see if a 2nd hdd needs to be set as slave or set in the cable select mode. Either right above the jumper pins or on the top of the hdd above the pins you should see 3 groups of 2 pins. They will be marked, ma, cs, & sl. They may not be in this order as each hdd manufacturer is different but all will have those 3 markings. If you set as slave cover the 2 jumper pins marked sl. For cable select cover the 2 pins marked cs. Hope this helps & please remember to rate my answer.
Jan 23, 2009 | Computers & Internet
I have an E-Machine W3107 desk top. I recently installed a western digital 120 hard drive as a slave but it would not jump. Can you give me any help in getting my system to jump. Thank you.
Jump? Ha! Never heard that term. How about boot?
Nowadays people just load drives as Cable Select; it should have worked with the old drive set to Master, but try to set them both to that and try again, or boot to a LiveCD or the drive utility disk so you can configure them on that. If they don't appear correctly in the BIOS, just double-check that power and data cables go to each drive, etc. You may need to follow the BIOS instructions or enter the BIOS controls by hitting DEL or F10 on powering up until the menu appears; then you can select the drive to try to boot first, etc. and save your settings.
Jun 23, 2008 | E-Machines Computers & Internet
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Installed 2nd internal Maxtor 4R120LO 120gb HDD as a slave
Your Ques is not so clear. i think you prob is this. your c drive is not havin enough of space. normally you shuold have about 20 gb if you are using big softwares like photoshop.try to get your primary partition more space..Need more help?
Mar 10, 2008 | Maxtor Hard Drive
2nd hdd
both hard drives will need to be jumpered to a master and a slave or both have to be jumpered to cable select. normally the jumper setting are either on the label of the drives or are marked on the bottom of the drives near the jumper drives. if the setting are not shown find the drive type, model and capacity then do a google search for the drive "select the factory manufacture link" and search their site for the jumper setting of the type drive you have.
Dec 05, 2007 | IBM ThinkPad T21 Notebook
Maxtor Hard Drive Logo
104 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
