Question about Citizen Aqualand Duplex JP104009E Wrist Watch
Can't set the hour on my Aqualand Duplex
I can get the seconds to flash, I can get the minutes to flash, but when I press the stem again the watch acts as if I am done changing the time.
  • 6 more comments
  • Anonymous Apr 05, 2008
    Having the exact same problem.
  • Anonymous Sep 22, 2008
    same problem as described above
  • jonnysuter Oct 26, 2008
    I am having the same problem with my promaster.Tried a system reset but no joy.
  • Anonymous Mar 08, 2009
    System reset doesn't work!
  • lazbarian Mar 09, 2009
    I just noticed that I have the exact same problem today when I attempted to adjust the for daylight savings time.
    Tried the system reset, but still cannot change the hour of date (only seconds and minutes).
    The watch is 3 years old and battery looks OK, but will try and send watch in for warranty repair to fix and get a new battery as well.
    Hope that will works!
    Otherwise, love my watch.
  • Anonymous Mar 28, 2009
    Can't set the hour, only the seconds and minuets
  • fab502 Mar 30, 2009
    Tried the re-set as suggested and just made the problem worse as before i was an hour out now I have the wrong date to ha.
  • foxaustralia May 11, 2009
    Same problem for me, just reset and now lost all data and now on wrong date.
I followed the instructions on the Citizen website for a system reset and it worked. Unfortunately, the regular way of setting the digital hour does not. Maybe a technical problem? The movement number for the Aqualand duplex is C506.
1. unscrew the analog adjustment crown and pull one click
2. press and hold the other 3 buttons for 3 seconds and release.
3. push the analog crown back and adjust the digital time.
this is a system reset so you will have to set the date. You will lose your settings and your dives. good luck.
Posted on Apr 02, 2008
When you can't change the hour, it indicates that the battery is getting low and needs changing.
Posted on Nov 03, 2012
Don't attempt the system reset as it wont resolve the problem!
I just did...still the same.
Posted on Aug 07, 2008
Change the battery. It fixed mine.
Posted on Apr 12, 2008
How to change hours
Timex Watch setting
Make sure you are in the hour/minute/second mode. Press "set" -- the seconds will flash. Then press "mode" again and the right minute number will flash. Press "mode" again and the left minute number will flash. Press "mode" again and the hour will flash. Press "mode" again and the month will flash. Press "mode" again and the date will flash. Any time any groups of these numbers are flashing, you can change the numbers by pressing the "start/stop" button. When you get the numbers you want, press "set" to lock in those numbers.
To change from 12 to 24 hour, get the hour numbers flashing and press
"split/reset." Then press "set" to lock in either 12 or 24 hour time...
Mar 14, 2015 | Timex Indiglo Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
My aqualung duplex alternates flashing seconds then "ER"in the lower display window, I've reset it as the manual instructs, after pushing the stem back in it beeps twice then starts the same...
This watch needs to be sent back to the factory to get the movement replaced. I am doing this for the second time in 4 years. Citizen Europe states it's a defective design. The watch goes into dive mode with sweat, humidity and washing your hands. The water sensor tells the computer it's gone diving but the pressure sensor isn't telling it the same thing which causes a fault with the computer. I was told to cover the water sensor with WAX by the factory repair facility. WAX on a $400 dive watch. Great. They shold have used the pressure sensor to initiate dive mode. Customer Service said it wasn't defective, so it was designed to need this part everytime the battery has to bre replace.
May 27, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
My citizen aqualand duplex watch has the word "chek" on the lower screen and it won't go away. What does this mean?
It turns to "chek" if the moisture sensor that triggers dive mode when you go in the water is exposed to water and you don't dive for more than an hour. The sensor is very easily triggered by sweat, so all you got to do is wipe the sensor between the crown and the upper right button with dry cloth and "chek" will go away.
Feb 21, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
Instructions for setting time & date of armitron watch 44/1001?
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Nov 08, 2010 | Watches
How do I change the time?
mcdevito75 here, The 2 buttons you need are the MODE and SET the MODE button usually on the right of the case next to the stem (winder) press and hold for 2--3 seconds, now see the display flashing if so then press the set button usually on the left of the caseing, after each function is set (hour, minute) press Mode button to move onto next function to set, after all is set, presss mo
de again for steady display. If this doesn"t work, see a small watch repair shop in your area.
Jul 17, 2010 | Watches
How do you set the time on the Roots Womens's Mai
Feb 05, 2010 | Watches
Citizen Aqualand Duplex JP104009E Wrist Watch Logo
1,457 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
