Question about Garland H283 Gas Kitchen Range
Griddle top for older Garland 283 gas range
I am looking for a replacement 24" griddle top for and older 283. Will a griddle top from a newer 283 work on an older model?
    Novelist:
  • 125 Answers
Hi, it may not, depending on the age difference of the units, the grease catch, etc.. contact Garland at www.garland-group.com , or call 1800 424 2411, the parts department should be able to tell you at least. Hope that helps, and thank you.
Posted on Jan 04, 2009
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
Broken ceramic diffusers below grill
Failing all else, from Garland themselves.
Our catering Garland has had replacements for the salamander, but they came from the local catering equipment supplies company.
I have also seen replacements on ebay.
Dec 12, 2013 | Garland H283 Gas Kitchen Range
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Griddle is warped
Hi, are you sure the griddle is warped, and doesn't just need to be shimmed on one of the corners ? that is all it may take to level it up again, some of the shims may have fallen out and are sitting underneath the griddle surface somewhere. Hope that helps, and thank you.
Jan 04, 2009 | Garland H283 Gas Kitchen Range
GE Adora Griddle Top replacement
part number for the griddle is WB31K10140
partstore.com has it for $87.95 hope it helps
Dec 23, 2008 | GE 30" Self-Cleaning Freestanding Gas...
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Garland range griddle top
make sure your unit is leval if you have alarge build up you will have to remove griddle and claen then reinstall
Sep 08, 2008 | Garland PS-36G-4-26 Gas Kitchen Range
Parts manual
Hi, you can call Garland Range at 1.800.424.2411, and talk to the parts department, or you can visit www.garland-group.com and in the top right corner is a "contacts" tab, and you can email them your request. Hope that helps.
Jun 02, 2008 | Garland H286 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
554 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
