RIM BlackBerry Curve 8520 Smartphone Logo
Posted on Mar 19, 2010
Trackpad freezes BB 8520 Options
I am new here, i got a blackberry 8520, i have it for 2 months now, few days back i am facing an issue where the trackpad continously freezes and then unfreezes. It keeps on freezing in long time intervals, i can click with it but i cannot move to any direction.
what can i do?
Appreciate any help
Thanks a lot
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1579
Points
5
I know what ur talking about and its so annoying what i do is i take the battery and sim card out and then put them back in and it seems to work only tho it takes forever!!!!
b2boy_007
Level 1:
New Friend:
  • Posted on Aug 04, 2012
b2boy_007
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1579
Points
TRY TO REMOVE TRACKPAD IC. IT"S TOP SOLUSION.
Bb 8520 comes up with charging sign with a red cross across on the screen. help!!!! Options
it happens when ur bb battery is damaged if u change ur battery u will not face that problem
Hey can you please unlock bb curve 8520 ...imei:357257.04.904092.1
Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost.
Here are the steps for unlocking a BB Curve 8520,
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
My blackberry scroll pad is not working, and i can't scroll anywhere. i took it to the shop and the man told me it was a hardware problem, i have pop reset it and soft reset it and nothing seems to work. i...
hi Titchypink.
this is all i could find out,hope it helps you out.
Trackpad, trackball, or keyboard not working on a BlackBerry smartphone running BlackBerry OS 7.1 and earlier Article Number: 000029640 First Published: April 26, 2017 Last Modified: April 26, 2017 Type: Support
Environment
  • BlackBerry smartphones running BlackBerry OS version 6 to 7.1
  • BlackBerry smartphones running BlackBerry Device Software 5.0
Back to top ?
Overview
In some situations, a BlackBerry smartphone with a trackpad or trackball may experience issues with sensitivity, latency, or scrolling. Additionally, the BlackBerry smartphone keyboard, or other buttons may be unresponsive.
Back to top ?
Cause
This issue might be caused by one of the following:
  1. The trackball/trackpad sensitivity needs to be adjusted.
  2. Make sure the trackball/trackpad is not affected by a software freeze or an application freezing.
  3. The BlackBerry Device Software is out of date and requires an update to resolve the trackpad, trackball or keyboard issue.
  4. The physical trackpad, trackball or keyboard hardware is malfunctioning.
Back to top ?
Resolution
Resolution for Cause 1
Complete the steps in Article 5447 to ensure the trackball/trackpad sensitivity is correctly.
Resolution for Cause 2
For BlackBerry smartphones running BlackBerry OS version 6 to 7.1 using a trackpad, complete the following:
  1. From the Home screen, select Options.
  2. Select Typing and Language.
  3. Select Trackpad Sensitivity.
  4. Ensure Audible Roll is selected.
  5. Rapidly roll the trackpad up, down, right, and left.
  6. If an audible click is heard while not responding, proceed to Resolution for Cause 4 as this could be a software related problem.
For BlackBerry smartphones running BlackBerry Device Software 5.0 using a trackball, complete the following:
  2. Select Screen/Keyboard.
  3. Ensure Trackball Audible Roll is selected.
  4. Rapidly roll the trackball up, down, right, and left.
  5. If an audible click is heard while not responding, proceed to Resolution 4 as this could be a software related problem.
  6. If an audible click is not heard, the problem may be related to a hardware issue. Please contact the wireless service provider for additional steps.
Resolution for Cause 3
To update BlackBerry Device Software using BlackBerry Desktop Software see, Article 11320.
or
To update the BlackBerry Device Software on the BlackBerry smartphone visit http://www.blackberry.com/update/
Use the BlackBerry Virtual Expert diagnostics application. For more information, see Article 35973.if not try this link. blackberry scroll pad is not working Google Search
3helpful
I have had my blackberry for month now and my blackberry messenger has been working fab but since tuesday i havent been reciveing messages or cant send messages and when i always wake up i have about 10...
I would reccomend trying
1. removing the battery (you've probably been told this before sorry)
2.. Deleting and downloading the most up to date version of BBM
3. Deleting your service books (Options>Device>Advanced>Service Books>BB Menu>Delete)
4. Registering device on the network (OPtions.Device>Advanced>Host Routing Table>BB Menu>Register)
hopefully that works out!
2helpful
I just updated my bb 8520 to 5.0, assuming that my frozen trackpad issue would resolve. it's still frozen. how can i fix this problem?
I would have thought if a software update did not fix this issue that it is a fault in the hardware. Contact your network/point of purchase to see if you can get a replacement.
4helpful
2answers
How can I reset my blackberry curve8520 myself?
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
Reload software552
How to reset BlackBerry Curve 8520 to factory settings:Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 • Cell Phones
1helpful
Trackpad on Blackberry Curve 8520 has stopped working, and whenever the phone is switched on, the trackpad heats up considerably.
i had the same prob with my bb 8520 .. i have got this info 4rm a site n it waz a video telling u how to remove ur trackpad ... i have removed my trackpad according to the video n cleaned the sides n the trackpad .. n connected it carefully ..Now it works Perfectly ! its not hard but its risky .. n now have a look at the video ' http://www.youtube.com/watch?v=-HgLXRgedvI ' believe me it really works :D !
9helpful
2answers
Track pad not working 0on 8520 blackberry
I had same problem and now solve it :) Just disassembly the phone and check trackpad connector ( just take it off and return on its place ) It will work perfektly :) U can find more videos for replacing trackpad on UTube .
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
