Timer on washing machine
Hi again. I posted another issue on my initial request from last month, but not sure if it went thru to you. I have been manually advancing my cycles on the washing machine, but today I thought I would try a different wash setting (I used Perm Press cycle instead of Ultra Clean) and the machine went through all cycles on its own from start to finish! Do you think it is still the timer? I have one on order thru Sears (160.+) but will cancel the order if I do not need it.
  • imnothandy Mar 10, 2008
    I just put another load of laundry in, and it is not advancing again. I tried the perm press cycle again (which worked an hour ago) but I did change the water level from medium to large. what the heck is going on?!
  • elgmar Mar 26, 2008
    We have a 1 1/2 year old Maytag Atlantis MAV8551
    The control dial will not advance. Once it is advanced to wash it will continue untill we realize the dial is not moving. We then manually set it to spin and rinse. The spn cycle will not advance and not turn off. Is this control unit computerized or mechanical? What is the repair procedure.
  • 770 Answers
Replace the timer
Posted on Mar 13, 2008
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
WE have a Maytag Neptune TL and it is stuck in the wash mode... as though the timer does not register to move on to rinse.
Katie,
I'm and owner that knows the machine very well. If you are someone has some basic skills you can repair the machine.
It will come down to how much down time you can tolerate.
What I think is the issue is that the Upper One-Way bearing is seized and when the machine enters into spin cycle of the selected wash cycle the washer can't spin the wash basket. The Control Board tries to enter the spin cycle over and over again. There is no software routine in the Control Board to sense this and the machine keeps trying execute the spin cycle of that wash cycle......Timer never counts down.....
Place that wash load in a Spin Only cycle. If my diagnosis is correct then the machine will do the same thing never count down on the LED display in the Spin Only cycle.
All these machine are ready for a Tub Seal replacement and I can direct most owners thru the process. The cost is in the area of $60 for Tub Seal, ****** O-Ring and Outer Tub bearings. If you need to replace the Clutch Pulley around $80 additional. If you are the original owner I'm sure you have been thru that.
Here is a link to replacing the Tub Seal and Outer Tub bearings. See if this is a direction you want to go. FAV6800A/FAV9800A Outer Tub bearing replacement
Here is a link to what I believe is your issue.........it just took me a long time to extract info from the owner on the failure. [FIXED] Maytag Neptune, Timer Problem
Maybe a FIXYA tech can jump in and add what they think might be the issue and a troubleshooting/repair path to follow.
You can make the machine last for a long time............way beyond the 3.5 yr. to 6 yr. point of most failures.........but each owner has to decide their course of action.
I go by dh1200s on most washer DIY forums including this forum.
Sep 06, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Fisher and Paykel MW511 washing machine but the water will not pump out can any suggest what to do?
Hey again. I wasn't for sure if you saw my last post but I wrote you a detailed post on what to check on your other post. Check your water pump inside the washer. Make sure it is working and make sure it is not all clogged up. Check your drain hoses also. Try unplugging the washer and plugging it back up also. This will reset it. Try changing the selections a few times (the timer) to see if this will help as well. Best wishes.
Jul 10, 2011 | Fisher Paykel EcoSmart GWL15
We have an Indesit washer dryer WDG1295. When switching on, it fills with water, hums away as though it is working (including draining) but the drum doesn't turn. The belt looks fine, and if you move the...
Immediate thought was the belt but you already checked that. Reading your message, you seem to be indicating the washer goes through the wash cycle and does everything except turn the drum, i.e. it fills and drains and the timer control knob advances as you would expect. This machine has an electro-mechanical timer rather than electronic, so if it advances through the program correctly, I would exclude this from my initial checks, but I'd still come back to it later.
Washing machines aren't that complicated, so if all of the above is true, the obvious assumption would be the drive motor. You've obviously opened up the machine to check the belt, so have you tested the motor with an ohm / multi-meter?
Please confirm the correct operation of the timer and whether you have tested the motor and I will try to assist you further. I check messages regularly, so if you post back here I should reply fairly quickly. Make sure you reply from within this page - don't post a new help request!
Regards,
BElectric
Nov 27, 2010 | Indesit Washing Machines
Timer goes thru all cycles to final rinse - to fast
HI. This is a defective timer motor. I would replace this defective timer module asap. Once replaced, this issue will be solved.
Oct 13, 2009 | Frigidaire FTF530FS Front Load Washer
Machine not functioning
HI, this is a damaged timer device. the mechanism has failed and , it is unable to correctly initiate the proper washing cycle. simply replacing the timer/control will fix this issue..
Jun 03, 2009 | Maytag Dishwashers
FILLS WTANK WITH WATER AND DRAINS BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
May 23, 2009 | Washing Machines
The Scan Dual IV will not initialize on startup although the door is closed.
 Hi I'm GusGusGus, I just posted a solution that might help. It's under the post about "2nd request for help on the scan dual 4", Hope it helps. Good Luck!
Jan 07, 2007 | Konica Minolta Dimage Scan Dual IV Film...
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
