Question about Denon AVR-2802
Hi Palmbeach, can you tell me which connections will give me the best results form my a.v. amp - component, digital, optical, or s-video, as I am confused with the different options the amp offers, m
A.v connections.
  • Quarkstar
    Quarkstar Mar 10, 2008
    Hi, amp is a denon 3802 and i am was wondering which is the better - s-video, component, optical, digital - to get the best audio/visual from my sources - dvd,x-box,pvr,cd,pc..I`m not sure which type of interconnects to buy. I apologise if this is an inappropriate question for this site, thanks Garry.
  • Palmbeach
    Palmbeach May 11, 2010
    Hi there
    What is the amplifier?
    Is it a Denon AVR 2802?
    What exactly do you want to do?
  • 185 Answers
Hi Garry
It's not an innappropriate question at all.
Take a look at the review >HERE<
The author Richard Elen has given some interesting information regarding the pros and cons of the different inputs and his recomendations of how to connect and set up, which should give you a few ideas.
Hope this helps
Posted on Mar 11, 2008
I am having trouble getting my surround sound to output my foxtel dvd using standard av cords is there anywhere i can get a diagram
Hi, I'm not too sure what you're asking - do you mean that sound is only coming out of 2 of the speakers? A lot of foxtel shows aren't meant for surround sound - usually only box office movies.
For best results, use a digital optical cable (not the one with a round end, one that's fibre optic, say that to a store and they will give you the right one) - connect to the optical/toslink input of your surround sound system.
You may have to turn on "dolby pro logic 2" to get all speakers working on some shows. Or you can try just plugging in the 2 red/white stereo cables into the amp, and using pro logic that way. Pro logic creates surround sound, even when your show is only stereo.
I guess that will do it .
Have a nice day.
Mar 02, 2011 | Yamaha Audio Players & Recorders
Hi, my tv is connected to my blu-ray via hdmi, but how do i connect my surround sound unit? Do i just connect the optical out on the tv to the optical on the surround sound unit? Will this give me 5.1 on...
This advice may fly in the face of the manual but it will result in the best sound and vision your gear is capable of.
You need to understand the directions audio NEEDS to go in order to manage it.
The BEST solution for watching and listening is to have the BEST electronics and the BEST devices handling the BEST sources of audio and video, respectively.
The FM & BLU-Ray are INTERNAL to the DAV so no cabling is needed for them nor will it affect them.
UNLESS your TV has superior sound to your audio equipment (unlikely), your TV is probably not going to be the absolute best AUDIO SOURCE. Many TV's (monitors) don't even have speakers so why should they be in the audio loop other than for watching news or weather?
Your Cable Box, Sat Box, any other external A/V sources will probably have facilites for presenting audio and video to separate devices. HDMI will carry digital audio and video. If THAT is the best a source has to offer, run it to the TV first as no signal ever benefits from multiple connections or 'hops'. That same high-end device probably also has a separate digital audio output. Run THAT to your best audio electronics for the same reason as above and to give it first crack at decoding the multichannel information it needs. Repeat for all other sources if you have inputs to support them everywhere. Lacking multiple digital audio outputs, opt for analog stereo to the lowliest audio device (the TV) and send the best to the Sony. That way, if you just want the TV on for company or news you can leave the Sony turned off.
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Jan 14, 2011 | Sony DAV-S888 System
I have hooked up the PS3 to my TV with the component cable. The audio is connected to a Denon digital audio device using an optical cable. I cannot get the sound to work, even though I have set up the...
I can't give you the exact steps without knowing the model of Denon receiver you are using, but usually you need to go into the setup of the AV receiver or amp and tell it to associate the digital audio input # you've plugged the PS3 into with a specific 'source'. The optical inputs will be associated by default to CD or DVD or CBL, but you usually need to go into the amps setup to specify exactly how you want it to use it.
I hope that helps.
Dec 19, 2009 | Sony Playstation 3 (PS3) Console
Without HDMI on the 3200, what's the best way to connect a Panasonic plasma TCP42S1 to get the best sound
Connect the digital audio output from TV to digital audio on receiver. It could be in different formats: 1 single RCA cable, optical, etc, Find the matching input on your receiver and voila!
For your picture, lacking HDMI, use COMPONENT cables: WHITE, BLUE and GREEN, I believe, for best results.
Oct 30, 2009 | Denon AVR-3200 Receiver
Is there a way to hook up a HDMI connector to my WS-48413
Yes, there are several ways to hook up your HDMI to your TV but first, we need to understand that HDMI carries both audio and video signals though a single cable in digital form.
I am assuming you want to connect a device such as a digital cable box, Blu Ray or HD DVD player with an HDMI output to your TV. Since your TV has both digital (DVI) and analog (S-Video, component, etc) inputs, my suggestion would be to get and HDMI to DVI adapter (about $20 at buy.com) for your video and for your audio, use any RCA audio cable (I use the one from the Dollar Store). This would give you the best video resolution from your source device.
My next suggested solution would be to get an HDMI to component video + audio cable (< $10 at eBay for a 6' length) for a single-cable fix. Again component video carries analog signals so the DVI could be a better viewing experience but because the cost of the cables are minimal, I would try both solutions to see which fix would give you the better picture.
Note that since the audio is being run though RCA connectors in both instances, the digital Dolby, 5.1 or 7.1 surround sound tracks in high definition sources will not be reproduced if you connect your TV's audio-out to your audio receiver. To get the best audio, I would connect the HDMI device's digital out (optical, coaxial, etc) directly to the receiver.
Hope that helps. Have fun!
Aug 23, 2009 | Televison & Video
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
I want to play mp3 music on a standard hi-fi kit. I have a Sony Vaio VGC-TP media centre with an S/PDIF optical output. I am intending to buy a Cambridge Audio amplifier and a couple of bookshelf...
HI,all you need to do is hook up the optical out put to the optical in on the amp this will give you the best sound, also try phono out of media centre if you have it as this has a higher band width.
HOPE THIS HELPS.
CABLE GUY.
Aug 18, 2008 | Sony Audio Players & Recorders
Just inherited a Pioneer F727 and need to connect it to a new Yamaha V863. The Pioneer has numerous connections as does the Yamaha. I will be using the disc player for both audio and video (CD/DVD). What...
If you have HDMI on your TV use the component video / digital optical from DVD changer to the receiver. Your receiver will upconvert the picture. The sound will also be sent via the HDMI. If you don't have HDMI still use the digital optical or the digital coax connections. The next best thing to HDMI would be using the component connections (RED, GREEN, BLUE) Good Luck
Jun 21, 2008 | Audio Players & Recorders
A.V. AMP CONNECTIONS
Hello...for best sound quality you should use optical or digital i.e sp dif depending what outputs you have on your cd/dvd..the easiest way is the sp dif because you can use ordinary rca cables....then for video you can use s-video or feed video signal direct to your tv via scart or rca input i.e video in but if you have hdmi from your dvd to tv you should us that for video, and i wish you good luck...Ron
Mar 10, 2008 | Denon AVR-2802
Denon AVR-2802 Logo
76 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
