Question about Sharp AL-1655CS Laser Printer
Top feeder of AL-1655CS
I have an AL1655CS that puts a line down the entire length of the page only when I make copies using the top feeder.
  • tompro Mar 11, 2008
    That was it, thank you so much!!!!
  • Anonymous Jun 04, 2008
    Your fix was the perfect solution. Got the little piece of glass sick and span clean and the machine is now like new.
    President:
  • 2,072 Answers
That is a dirty glass. The 1 inch or less wide glass on the left side of the machine has a very small spec on it.
You can clean it with a regular piece of paper and alcohol. Don't be afraid to clean it with some decent pressure.
The reason why you get the line in the feeder and not off the glass is that when you run a copy off the glass the lamp scans the immage, when you run through the feeeder the lamp parks under the glass and the movement of the document makes the print.
You may have some white out, or just some ink off an original on that piece of glass, but keep that clean.
Most people don't think that small piece of glass has a purpose, but it does. Sometimes the blot on the glass is so small you cant see it, and you need to remove that glass and hold it up with a piece of paper behind it to see the spot. It can be a very very small spot. But that is where your issue is.
Posted on Mar 10, 2008
  • Rick Kasper Mar 10, 2008
    99.999999999999999 percent fix.
  • Rick Kasper Mar 11, 2008
    Your welcome.
HI. My Sharp AL-1655CS Laser Printer is making an extremely loud noise when printing and when the paper comes out its all jammed like an acordion. Can u please help me?
It's going to be the fusing unit that needs to be replaced. It's also a good idea to replace the gear in the machine that drives the fuser at the same time. Both are available here: http://olsonbros.com/sharp/specs/al1655cs.html
Sep 02, 2011 | Sharp AL-1655CS Laser Printer
Sharp al-1655cs where is the scanner head locking switch?
On my Sharp AL-1551CS, it is located on the left end underneath the scanner unit.....it is a knob that rotates only 1/4 turn to either lock or unlock.
Feb 26, 2010 | Sharp SHP AL1655CS Printer, Scanner,...
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
6310 has a fine black line down the entire length of the page
Need the clean the pinch rollers on the top of the unit. Use a small amout of alcohol on a piece of paper towel. Clean all the pinch rollers and then let unit sit for about 15 to 30 minutes.
Feb 18, 2009 | HP Officejet 6310 All-In-One InkJet...
Don't know how to input an error correction code
Here is the manual for your unit.:
http://www.sharpusa.com/files/cop_man_soho_AL1642CS.pdf
Please remember to rate all users who assist you for free :)
Sep 16, 2008 | Sharp AL-1655CS Laser Printer
E1-00 code on Sharp al1655cs
TRY THE CODE 80-21 IT COULD HELP
Jul 24, 2008 | Sharp AL 1631 Copier
Single line printing in copy mode
CLEAN OFF GLASS ON TOP WITH WINDEX THEN RETRY COPIER
Jan 17, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Laser Printer Logo
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
