Question about Compaq Presario 700 470024-192 Notebook
Help!!!!!!!!!!! My labtop is not working the light on the ac adaptor is blinking and my labtop wil not turn on can you tell me how to fix it?
I install vista ultimate in presarioc700 but i cannot install the wireless driver.when i scan it found the atheros ar5006x but there have a problem and i cannot use the wireless....and when i install windows xp,i cannot find the suitable driver for sound..plez help me
Posted on Mar 29, 2008
My laptop wont turn on. i also doesn't blink 3 times when i press the power button with the ac adapter plugged in. i tried taking off the battery and holding the power button on for 1 minute but that still...
Does the blue light come on at the side where you plug your ac adaptor in? If it does, and your laptop still wont turn on, its likely you have a motherboard failure. Also try this without the battery inside. If the light is not coming on the charger port at the side, then its most definitely your ac adaptor at fault.
Jul 22, 2010 | HP Pavilion dv9700t Notebook PC
I Dell Labtop is not turning on. 3 lights blink continuously
do you still have your battery working? if not, you may have a problem with the adapter. could be a partial contact from the main adapter or at the charging port on your laptop. use a tester and check for continuity on the adapter cable and also check the power output going into the laptop.
Jul 22, 2010 | Dell Inspiron B130 Notebook
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
Hp zd8000 wont turn on...
hi thanks for using fixya!!
Try first to remove the battery and connect the AC adapter to your laptop, you will use the power supply directly from the AC adapter without the battery. Turn on your laptop, then if its working normally as it should be,
Then try now to install back the battery then connect the AC adapter, turn it on. If still does not work, perhaps you have a problem with the battery.
If you need further assistance, let me know.
May 24, 2009 | HP Pavilion zd8000 Notebook
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Toshiba Satellite 1405 - Power problem
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Jan 21, 2008 | Toshiba Satellite 1405-S151 Notebook
Compaq Presario 700 470024-192 Notebook Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
