Netgear connection problem
I've just got a netgear DGB111G - why will it not connect to the internet? - I currently use a speedtouch connection
  • 2 more comments
  • graham956 Mar 10, 2008
    it's the same thing isn't it? I tried switching on & off no sucess other than internet indicator was red (no connection)
    thanks
  • graham956 Mar 18, 2008
    Hi, thanks again - I have no WAN - I have ADSL & then four LAN ports - I am going to get in touch with my provider (Orange)
    thanks
  • graham956 Mar 22, 2008
    Yes thanks,
    the NETGEAR device is a Wireless ADSL2 + Modem Router
  • graham956 Mar 23, 2008
    thanks
    Yes it is - it is a NETGEAR Wireless ADSL2 + Modem Router
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 35 Answers
After you connected the new router to your modem (using the WAN connection on the router) did you restart the modem? Try restarting the modem and the router.
Posted on Mar 10, 2008
  • 1 more comment
  • Wayne Hammond Mar 10, 2008
    The device you had originally connected to your computer is the modem. It translates the signal from your internet provider into an ethernet connection which can be used by your computer. The wire that was plugged into your compter originally should be plugged into the connection marked "WAN" on your router. It is usually located away from the group of internal connections (4 or 8 normally depending on your router). After you make this connection, you will need another RJ45 cable to connect the computer to one of the grouped ports, If you are using a wireless connection, you may still have to connect with a cable to set the router up, then disconnect and use the wireless connection from then on.
    Also, many times the connection between the router and the modem is a different type of cable. It s best to use the one that came with the modem if you have it. You can check with tech support of your provider to help you too.
  • Wayne Hammond Mar 19, 2008
    Are you saying the device provided to you from your ISP has 4 connections? If so, perhaps the device is already a router.
  • Wayne Hammond Mar 23, 2008
    If the router was supplied by your provider and is not connecting to the internet, then you must call your provider. There may be a problem with your connection to the company network. When you call for support, the agent will be able to check the router remotely to see if there is a problem. If the agent cannot connect, then the line repair section will be dispatched.
Drivers for ADSL DGB111G router
No, the drivers only go up to Windows XP.
However you do not need the drivers to setup the router if you do it manually over a Ethernet connection.
You only need a copy of the manual to login correctly.
But it is no longer available.
Sep 15, 2013 | NetGear DGB111G Wireless Router
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
Tried to install Netgear DG834 router ~ no internet light
Try changing your router to BELKIN which has life time free warrenty and free replacement if it does not work
Jan 13, 2010 | NetGear DG834 Router
Do i have un install my speed touch modem to install netgear dg834v5
Hi, please note that speedtouch modem and DG834G router will not work together. Rather DG834G will replace the speedtouch modem. Remove the speedtouch modem and follow the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually http://192.168.0.1).
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 05, 2009 | NetGear DG834G Router
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access...
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Oct 26, 2009 | NetGear DG834G Router
Wireless INstallation
you need to ring your ISP to get a network user ID and password, when you enter these in to the router settings the Internet light will light up green.
Jun 08, 2008 | NetGear DG834G Router
Setting up netgear dg834gmodem router
u will need to call netgear get your isp or ther dns server codes they will tell u it and u will enetr in the network adpoters properties area ok thx nick
Mar 13, 2008 | NetGear DG834G Router
Netgear DGB111G Starter Kit
Path #1:
Change all of you cordless phones to another frequency (Other than 2.4 Ghz).
Path #2:
If the netgear is in the same room as you, couldn't you plug in directly an ethernet cable into the netgear? You could buy an ethernet cable at any computer stores around and they go up to 30 feet. And no CD installation would be needed, it should just work with a wire to another wire.
Dec 27, 2007 | Computers & Internet
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
