If you are set up with ethernet, you should be able to remove it throught Centreware Services. Just typr in the IP address of the printer. I think it is under the maintenance tab. You may need the admin password
That sub folder is in a windows protected folder. See if you can create a folder un your libraries subdirectory and name is scanned docs. Then tell the scanner to send it to that folder
In the Folder List, in the Navigation Pane, right-click the folder you want to delete.
On the shortcut menu, click Delete folder name.
Notes
The default Personal Folders file (.pst), which is set as the default folder for receiving new messages, cannot be deleted. If you have duplicate Personal Folders, you can remove the duplicate folders from the Folder List. Removing the duplicate folder doesn't delete the data file, which remains on your computer's hard disk.
When you delete a Search Folder, only the folder is deleted. Search Folders are virtual folders that contain views of all Items meeting certain search criteria. The items shown in the deleted Search Folder remain in their original folders.
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
Click Start and right-click Computer .
Select Properties .
Click System Protection from the left side of the Window.
In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window.
Figure 3: System Protection tab with D: drive unselected
Right-click Start Explore All Users .
Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
From the file menu, click Tools , and then select Folder Options .
Select the View tab.
Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
From the Folder Options window in explorer, double-click Recovery (D:) .
If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
Find and delete any files that you previously copied onto the Recovery (D:) drive.
CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
Press Shift + Delete to permanently remove the files.
To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
To set Windows Folder Options back to their original setting as follows:
From the explorer window press Alt to view the file menu.
Click Tools , and then select Folder Options .
Select do not show hidden files and folders and select Hide protected operating system files .
Click OK .
Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
If you are getting a message about not having a default page setup after uploading your files, make sure that you have uploaded your files to your class directory in your folder. For example, if you are in IT117-05, make sure you are in your IT117-05 folder before uploading your files. To do this in the web interface, double click your class folder in the right pane to enter the folder. Once you are in the folder, upload your files. Also, DO NOT DELETE your class folder. If you are using Dreamweaver and getting this error, make sure that you have your remote folder set to your class folder name.
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Hi kathy_skip If you remember the name of the saved file, use a search. Some scanners give the name like scan000,scan001,scan002 etc
If you have no idea what the name was, then scan another document (if you don't have the previous one) and watch the name of the file and folder where it is saved. You may find your previous scan next to it in the same folder. Best of luck luciana44
I Had the same issue, worked on it for weeks, was told it was registry issue, I reinstalled the software, said it was hardware problem....THEN I FOUND THIS AND as simple as it seems, IT WORKED. Please follow the instructions below to help resolve this.
Go to My Computer, by right-clicking the Start button. Select Explore
Double-click the C: drive, then navigate to the following folders or location on the hard drive: C:\Documents and Settings\%username%\Application Data\EPSON\ESCNDV\ES00XX (where XX is any numbers or letters)
Look for a BMP file or any file in this location and delete this file OR FILES THAT ARE .BMP.
, can be xxxxx.BMP ( where xxxxx is the name)
Note::
%username% above stands for your PC username.
The Application Data folder is hidden by default, to un-hide this folder do the following in your Windows Explorer window go to the Tools pull down menu and select Folder Options
Click on the View tab, look for Hidden files and folders.
Select Show hidden files and folders option
Click OK.
you should now be able to see the Application Data folder continue in to the folder path above. (You may have to follow the steps again to turn off the Show hidden files and folders feature. )
Removal and reinstallation of Epson SCAN does not clear out this file.
It is very unusual for only one folder to cause problems in OE6.
Is the folder missing or is it there but empty?
Are all the other folders ok?
Try sending a new email and see if it appears in the sent folder?
Try doing a full virus scan.
Clear out old temporary internet files.
Check that OE is operating correctly and not freezing.
You could try using System Restore to take your computer back to a point when it was working correctly.
If the folder is missing completely, it could be that OE6 has been corrupted by a virus and is unable to read the folder. All the OE folders on your hard drive have the extension .dbx. You can search for them using find files and folders. You will only be able to open them with OE.
When you see the File Save Settings window, you need to select the location, name, and format of the scanned image file you want to save.
In the File Save Settings window, specify the file folder in which you want to save your scanned image. Click the My Documents or My Pictures radio button (Windows XP or earlier versions), or the Documents or Pictures radio button (Windows Vista or Mac OS X).
If you want to select another folder, click Other, then click Browse (Windows) or Choose (Mac OS X) and select the folder. If you want to save your image on the desktop, simply click Other.
Specify a file name prefix with an alphanumeric character string. A 3-digit number is automatically added to the file name, but you can change the Start Number if you like. If you are scanning multiple images at once, each image will receive a different 3-digit number.
Select a file format. Depending on the format, the Options button may be available for making detailed settings.
The check boxes at the bottom of the window give you these options:
Overwrite any files with the same name: Select this option if you want to reuse the selected file name and location and overwrite previous files with the same names.
Show this dialog box before next scan: Select this option if you want the File Save Settings window to appear automatically before you scan in Home or Professional Mode. If you deselect it, you must click the File Save Settings button to open the window.
Open image folder after scanning: Select this option if you want Windows Explorer or the Macintosh Finder to automatically open to the folder where your scanned image is saved when Epson Scan finishes scanning.
6. Do one of the following, depending on the currently selected scan mode:
Home or Professional Mode: Click OK. Epson Scan starts scanning.
Full Auto Mode: Click OK, click OK again, then click Scan. Epson Scan starts scanning.
The scanned image is saved in the file and location you chose.
This question is regarding a xerox phaser 8560mfp
