Emerson Fans Emerson MW8115SS Microwave Oven Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dropped microwave now it dont work but light is on
Anonymous
Level 3:
  • Emerson Fans Master 43,501 Answers
  • Posted on Aug 07, 2010
Anonymous
Emerson Fans Master
Level 3:
Answers
43501
Questions
0
Helped
10845191
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
1helpful
2answers
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
2answers
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Not heating anything up
if the light comes on and you here it buzzing but its still not heating up its likley to be the megertron burned out,, (thats the aerial for the microwave's to transmit off) its very expenive to replace,,,
bont try replacing it yourself, inside the microwave is very high voltage even if its been turned off for a long time,, 1000's of volts and they kill,,
have you ever seen a stun gun working??? this microwave has the stun guns very big brother inside it?? it dont stun,, it kills! play it safe drop it into a repair man to fix or better still buy a new one,,there so cheep now its realy not worth spending good money on an old microwave,, go out and treet yourself and play it safe!
1helpful
Maytag microwave Model MMV5100AA turntable no longer turns. Is this an easy fix? The rest of the Microwave works fine. I think I may have flooded the floor of the microwave with water. It worked awhile...
to be realy honest ,,, yes! but be warned there is a very big capacitor inside this microwave and it will be charged up with 1000's of volts,
if you tuch it, your dead! be warned dont tuch it!!!!!!!!!!!!!!
have you ever seen a stun gun working??? they realy hurt you!!!!
well this microwave has the stun gun's very big brother inside of it and it wont stun you,,,it will kill you!
if i were you i would drop it into the repair man to get him to fix it for you,,, or get a new microwave,, there very cheep now,, is it realy worth killing your self for a fuw bucks?
MY MICROWAVE WONT START BUTTONS WORK BUT WONT
the problem with microwaves is there like light bulds,,, fine for years then the just pop off, whatever it is there is very little you yourself can do with it bar check the plug fuse,, if thats ok dont even think of opening it up to have a look inside, you are very likley to just kill yourself
inside that microwave is a big capacitor that holds 1000, of volts and they can and do kill if you tuch the wrong bits of them,
have you ever seen a stun gun work? well that capacitor is its very big brother, only it wont just stun, it will kill you out right...is it worth the risk??? no! so drop it in the shop for repair or better still bump it and get a new one,, and up grade it as well,
Microwave dont work after short with light bulb
your internal unit fuse has opoened
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Microwave quit
I dont know if this is going to work but qhat the heck do you have to lose
unplug it for a few min. then plug it back in
2answers
Hood Lights not working
The problem lies in the circuit board / control panel. We regularly repair these control panel assemblies nationwide for 32.50.
Top Emerson Fans Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
