Question about Compaq 7500 17" CRT Monitor
Screensaver color: Screensaver comes on in color,ok ;the next time it comes on, it's in B&W,next; it's color again. And back & forth.
  • Compaq Master
  • 19,396 Answers
It is your monitor video cable. Check that is well plugged, if its well plugged and you still get the problem, then probably the cable is faulty.
regards
Posted on Mar 10, 2008
Screensaver stuck
Sounds like you have a runaway process that is consuming all resource. Sorry but you'll just have to hold down the power button until the machine shuts down. Then restart and you should be ok.
Nov 17, 2013 | Apple Audio Players & Recorders
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Lenghten time before screensaver comes on
Go to start and type "Screen or Screensaver" it should bring up a choice in the grey menu. Click is and go to Timer and add you time. Or scroll the bar till it says NO screensaver
Aug 29, 2013 | Fujitsu LifeBook A1110 Notebook
How do i set my timer for my screensaver-when my laptop is idle?
The option is under Screen saver options or there is an idle time shut off selection under Power Saver options as well. When you select your screen saver there is are specific options to customize how it shows and how long before it activates. Some screen savers have more options than others.
Oct 29, 2010 | Computers & Internet
I go to Display and choose my screensaver and
check the screensaver time out whether you gave it time for it to display itself if not indicate it there and recheck it ok
Feb 20, 2010 | Acer Aspire One PC Notebook
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
When I go to my desktop after a minute or two the entire screen goes white, how do I fix it?
This sounds like a power save issue or a screen saver problem and they are both on the same panel I will lead you to
Right click on an EMPTY part of the desktop then click properties
Click the screensaver tab then the POWER settings.
Make sure all the boxes say NEVER then APPLY.
Its up to you if you want it to ask for a password when it comes off the screensaver (my pref is for no) then click apply then ok.
When you are back at the screensaver tab change both the screensaver to one of the other windows defaults and also check how long before it goes to screensaver and maybe up that to at least 15 minutes unless you have a plasma screen in which case no more than 5 minutes.
you may need to click apply again then OK
now sit back and wait. and whilst you do that check the manual and controls for the monitor in case it too has a built in saver and if so make any changes you need there.
If you found this information useful then please click
Aug 13, 2009 | Relisys RLT1720 17" LCD Monitor
No screensaver will activate on my computer
To activate screen saver right clik on the desktop go for properties click on screensaver tabselect screen saver adjust the time to 5 and click on apply and ok button. so that ur screen saver is activated to the selected time.
Jul 07, 2009 | HP Pavilion dv9000t Notebook
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
