Question about LG Chocolate Clamshell VX8600 Cellular Phone
Trying to pair with bluetooth
Having a problem. Keeps searching and can't find device.
  • Charpsie Apr 29, 2008
    also having a problem pairing the LG VX8600 with a nuvi 660 gps. Anyone else?
  • cyaro Apr 29, 2008
    Same problem here...unable to pair my VX8600 to Insignia headphones. The phone remains in a "Searching" state and does not find any devices.
I have a Motorola H500 headset & was having the same problem. I think it's all in the timing. With the headset off, hold down the Call button for 6 to 10 seconds until the light stays lit--solid light, not blinking. This is when the headset is in "discoverable" mode. Immediately access the settings & tools menu on the phone, then to the bluetooth communication settings to locate & pair the phone with the headset. Hope this helps with your devices.
Posted on May 14, 2008
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
I have had this bluetooth for a while but never used it. Trying to pair it With my new iPhone and dont remember having a PIN #. what do I do now? Or can I use it?
The default pass code is "0000."
Here's how to pair it with the default pass code:
  1. Turn the Bluetooth on and hold down the button until the light turns solid.
  2. Put the phone in discovery mode or search for a Bluetooth device.
  3. Pair the Bluetooth to the phone and enter the pass code "0000"
May 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Dec 04, 2010 | Blueant Z9 Wireless Headset
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
I cant talk to anyone and how do you talk to them
Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
Oct 21, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
I am trying to sync a new bluetooth (sprint brand) to my blackberry curve 8330 I have bluetooth enable and have searched to locate the bluetooth earpiece and it keeps saying can't be found
You have to make sure the bluetooth is in a pairing mode for the blackberry to discover it on most bluetooth they have a pairing button turn off your bluetooth headset hold pairing button till the light is solid or flashing red and blue depending on model then search for new should find it
Sep 24, 2009 | Cell Phones
Pairing bluetooth to my phone
  • general instructions for no specific phone and device to pair
    • turn on both devices (phone and other device)
    • on the phone search for a bluetooth devices(that is on)
    • if the other device is asking for a password, enter a known password to success the pairing
    • or else it will pair automatically for a non password pairing
May 03, 2009 | Lands Phones
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
Im trying to hook a bluetooth to this phone and It keeps saying it cant find it...
Be sure that your device's Bluetooth is not only on, but is discoverable by other devices. Also, make sure that your Bluetooth device is in pairing mode before you search devices from your phone.
If you can provide me with the model of your phone (Under the battery on the phone) and the type of Bluetooth you have I can help you further.
Dec 18, 2008 | Cell Phones
Bluetooth keeps flashing
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Sep 24, 2007 | Motorola Mobility H350 Wireless Headset
LG Chocolate Clamshell VX8600 Cellular Phone Logo
98 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
