Question about Acme 5001 Supreme Juicerator Juice Extractor
Acme 5001 on / off button
Hi..when i moved the on/off button feel into the base and i cant seem to get it out to turn it on. i tried to unscrew the bottom but stuck after 18 years iv had this wonderful product..help! i live in vegas..who could help me? it still is the best..thanks! Lisa at olamakeup@gmail.com
    Champion:
  • 356 Answers
REMOVE THE 4 BOTTOM SCREWS AND
TRY IT AGAIN. YOU CAN SEE THE SEAM
AROUND THE JUICER WHERE IT SEPARATES.
YOU CAN GET THE SWITCH FROM WARING
AT 800 492 7464. MINE IS FROM 1990 AND
RUNS LIKE NEW. DO ALL MY OWN REPAIRS.
Posted on Jun 30, 2009
Motor runs and is seem like it has a clutch that is slipping. Tried the re-set button. The re-set button does not seem to engage anything. Took the 4 screws off the bottom but do not see anything that...
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
Apr 03, 2011 | Acme 5001 Supreme Juicerator Juice...
I am not able to turn my Acme Juicerator on.
Try the reset button on the bottom of the juicer.
Dec 23, 2010 | Acme 5001 Supreme Juicerator Juice...
My Acme 5001 Juicerator vibrates around on the countertop. The rubber pads seem to be falling apart. Can I replace them? Where do I get them? Thanks David II
Dave, contact Waring at 1-800-492-7464 and order
a new foot ring. Here's a tip. When the juicer is
not in use find a bowl cover or something to fit
in side the circumference of the foot ring for the
juicer to rest on. That way the foot ring won't
stick to the counter and rubber won't compress
over time.
Nov 09, 2010 | Acme 5001 Supreme Juicerator Juice...
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Sep 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Acme 6001 / 5001 manual
GO TO WARINGPRODUCTS.COM AND VIEW
THE MANUAL FOR THEIR NEW JUICERS.
THEY ARE THE SAME AS OLDER ACME'S
Jul 23, 2008 | Acme 6001 Juice Extractor
Cleaning
http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Jul 12, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
96 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Are you an Acme Juicer Expert? Answer questions, earn points and help others
