Only delicate cycle work correctly, the other 2 cycles will fill but not agitate or spin, timer cycles o.k
  • Anonymous Mar 22, 2009
    my maytag washer agitates on delicate cycle but not on permanent or normal cycle
    Novelist:
  • 131 Answers
It's probably the motor. Most times, the motor has separate windings for slow and fast speed. Before spending $120. 00 on a motor, I'd get a $5.00 voltmeter to confirm this. You can use the tech sheet to find which terminals on the motor are the fast speed windings, and check the resistance. Be sure to unplug the motor plug first. It should read about 8 to 14 ohms.
If the motor is good, the timer is the next likely candidate. Withoput knowing which machine you have, this is the best I can do.
Posted on Mar 10, 2008
2 Suggested Answers
  • 319 Answers
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
Replace it
Posted on Jan 04, 2008
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
My LAT9635AAE washer will only agitate on the delicate cycle. the timer goes thorugh the cycles on the other settings, but the agitatior will not move
You have a problem with the contacts in the timer and it will need to be replaced. Here is the part to order. To replace the timer remove the cover on the back of the console.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag Washing Machines
Delicate cycle fills with water but will not agitate
Timer needs cleaning on the delicate relays (points) in the delicate position. Maybe timer failure. Transmission stuck, jammed or failing in that wash mode
Sep 21, 2012 | Estate Washing Machines
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer, lat9606aae only works in delicate cycle and hand washable
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Dec 18, 2007 | Washing Machines
Washing Machines Logo
190 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
