Incorrect level. Check level at operating temps and while the engine is running. By sump and stainer you meant that you removed the oil pan off the car and cleaned the pickup tube of the oil pump? I'd suggest hooking up an oil pressure gauge so you'll know which part of the engine is starving oil and setting the warning.
The system works like this.
If either of this two warnings occur:With the ignition on, the oil pressure indicator light on the dash should come on and flash. Once the engine is started, the light should go out and stay out as long as the engine is running.
If the oil pressure drops below approximately 0.3 bar or 5 psi when the engine is running below 2000 rpm, the light will flash.
If oil pressure drops approximately 1.8 bar or 27 psi when the engine is running above 2000 rpm for more than 3 seconds, the indicator light will flash and buzzer will sound.
The engine should be switched off immediately and oil level should be checked.
Thanks for the suggestion it was helpful but the oil pressure was checked by a vw machanic he left car running for a substatial amount of time and said it was ok. could it be the pump?
