Question about Boss RIP-895 Car Audio Amplifier
Fuses what kind of fuses dus this amp need
    Sergeant:
  • 290 Answers
I'm not sure what kind (aka shape) fuses they are, but the manual says there 2x 20A fuses.
Posted on Mar 13, 2008
1997 malibu heater is working but only cold air coms out
1. Make sure the coolent is full.
2. Check all the fuses.
3. If all that is okey the Blend Door Actuator (BDA) is most likely the cause.
Mar 09, 2013 | Cars & Trucks
Power steering fuse needs to be replaced, know what kind of fuse don't know where it is located have throughly check manual and car
on the door/lid of the fuse box there is a numbered or labeled diagram shows what fuse goes where and what amp it is
Oct 28, 2012 | 2007 Chevrolet Chevrolet Equinox LT
I have a 1999 Dodge cuts off at idle.... will start right back up but if I dont keep the gas coming it shuts right off again.... I was hoping that it could be a fuse but not sure....
you need a idle control valve , look here http://images.wrenchead.com/smartpages/partinfo_resize/DUS/217-1781.jpg thats what it looks like,
Jul 31, 2011 | 1999 Dodge Stratus
Hallo mijn mic doet raar van mijn blackberry hij kraakt kan persoon aan andere kant niet verstaan, wat kan dit zijn?
je moet hem terugsturen naar je provider, dit is een veel voorkomend probleem en moet worden gerepareerd. bij vodafone kan het 2 weken duren voordat je je blackberry weer terug hebt. sorry zit niets anders op ik heb het ook :(
Jan 31, 2011 | RIM BlackBerry Curve 8520 Smartphone
Need to know what kind of fuse ans amps go in my flstc 2000 dont have the diagram for the fuse box! no flasher, no brake light, no speedometer, need held ! Danielle
I do not have a schematic for model bike either but most bikes have a 30 amp Main fuse or breaker with all the other circuits being protected by 15 amp fuses or breakers.
Good Luck
Steve
Jun 13, 2010 | 2000 Harley Davidson FLSTC Heritage...
Need fuses for samson amp
The manual recommends 4 Amp Slow blow for 115 volt operation or 2 Amp Slow blow for 230 Volt operation for the 201a.
http://s3.amazonaws.com/samsontech/related_docs/Servo201a_OM_5L_v1_1.pdf
For the 260 Amp manual shows 10 Amp normal for 115 volt operation and 5 Amp nomal for 230 volt operation.
http://s3.amazonaws.com/samsontech/related_docs/ACF1AAF.pdf
Dec 31, 2009 | Samson Audio Players & Recorders
Dus not have sound
Hello keith_freema,
It's possible the sub is defective or isn't getting power from the amp.
Connect the sub to another output temporarily to determine which is causing the problem. If the sub workd on another output, look at the amp. Check that it is powering up properly. Check the onboard fuses and speaker wiring.
Hope this helps.
Aug 31, 2009 | Car Audio & Video
I need to know what kind of fuse my amp takes...
IT MAY MEAN THAT IT TAKES (2) 25 AMP FUSES
IF YOU HAVE THEM OUT SEE IF IT SAYS WHAT THEY ARE OR OPEN IT UP IT MAY SAY IT ON THE BOARD OR THE FUSE HOLDER OR LOOK @ THE SPECS ON THE AMP SEE WHAT THE TOTAL CURRENT IS YOU CAN ALWAYS START WITH A SMALLER AMPAGE LIKE 10 -20 AMP FUSE ALWAYS GO SMALLER
Feb 15, 2009 | Sony GR-6.1m Gravity Mono Channel MOSFET...
Amp fuse
There are two 40 amp fuses in the unit I have.
May 19, 2008 | Logic Soundlab CPX1820 Car Audio Amplifier
Boss RIP-895 Car Audio Amplifier Logo
77 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
