Question about Lexmark X73 All-In-One InkJet Printer
Installing My lexmark x73 will not print, so I'm trying to reinstall it. was told that I had to uninstall first, so I did, now while trying to install from my discs, the computer shuts down, restarts and still does not have the printer installed. This continually happens - I have tried reinstalling it probably 5 times today. HELP!!!
    Genius:
  • 3,587 Answers
I suggest you use the drivers you'll find here, instead of the original cd(which may be completely outdated)
click here for those links
Posted on Mar 10, 2008
When I try to print from any application - nothing happens - the printer window opens but it does not pick up which file is to be printed.
You need to completely uninstall the printer driver and before uninstall it make sure that printer is not connected with computer. once when uninstalltion get finish restart the computer.
now download the latest driver from lexmark website, you can search it with printer model number and install the printer.
Oct 23, 2009 | Lexmark X73 All-In-One InkJet Printer
I am having trouble installing my Lexmark X73 printer. It's also saying its not connected to my computer when it is
unplug it uninstall all the software reinstall the software abd when prompted plug in the usb cable.
Oct 18, 2009 | Lexmark X73 All-In-One InkJet Printer
Printer works, copier and scanner do not
you might try enabling bi-directional printer support in printer properties, if its paralell cable then it is in bios, epp or ecp.
Jul 27, 2009 | Lexmark X73 All-In-One InkJet Printer
Lexmark x73 no installation disc
I have cd's for x73.
and two color- Lexmark 20- ink [unopened].
let me know if you are interested
Apr 13, 2009 | Lexmark X73 All-In-One InkJet Printer
Properties Settings for my Lexmark X73 are missing
Hi Bobby,
Good idea! Uninstall the Lexmark software. (Restart windows).
Before you reinstall the driver software download this free cleaning software & run it.
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
(Restart windows again when it has finished cleaning).
Rather than using your CD's go to the link & download the driver software. I'm not sure if your CD is the same (Date wise) or if the web site's software is the latest. Re-install the driver software.
While at the Lexmark link above, scroll down to the drivers section.
You'll see that Lexmark does not support Vista. From forum post others with the same printer post it will not function with Vista.
Here is a forum site about Vista & the X73;
http://www.vistax64.com/vista-hardware-devices/172631-lexmark-x73-printer-wont-work-vista.html
Good luck Bobby!
Mike
Mar 26, 2009 | Lexmark X73 All-In-One InkJet Printer
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
I am trying to print from my Lexmark X73. I have reinstalled the software, but it's not installing the printer portion. It is only installing the scanner. Why is it doing that, and can I fix it?
run this clean uninstall utility
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:94:0:0&emeaframe=&fileID=1236&searchLang=en&os_group=WinXP
download the drivers from lexmark
http://www.downloaddelivery.com/downloads/cpd/CJXP73LE.exe
plug in your printer and install the drivers.
if this does not work then extract the driver file you downloaded "CJXP73LE.exe", go to start ->settings->printer and faxes....install a new printer (make sure local printer and auto-detect are checked)...follow it through and your printer should install. if at any time it asks for drivers or you want to manually point to the drivers then browse to the location where you extracted the "CJXP73LE.exe" file. you can download a program like "winrar" (type it in google) to extract it.
Feb 23, 2008 | Computers & Internet
Scanner will not scan
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark x73 printer
Install or reinstall driver from Lexmark... here is the link below http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X73
Sep 16, 2007 | Lexmark X73 All-In-One InkJet Printer
Cannot print unless I turn off computer and then reboot.
I'm not a big fan of Lexmark in general in part due to their software and drivers. For me this type of behavior from their printers/software became common about a year ago, the fix being to use the more generic Windows supplied printer drivers. I would suggest that you uninstall all software the printer installed and remove all of the printers print queue(s)including any associated with the fax function. Unplug the printer USB cable from the computer, reboot your PC and reinstall the printer from scratch using your original installatin CD.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
