Question about Toshiba 36A43 36" TV
Remote will not function with TV
Changed batteries in remote, no affect. Bought identical remote, no affect. Buttons on face of TV will work properly - can power up, change channels, affect sound. Any thoughts ?
  • 1 more comment
  • maldoms Mar 10, 2008
    Jaime, thanks. Don't quite understand your second sentence "can you provide exact TV model number ........". I got the model number off of the sticker on the back of the TV. There were no further numbers. It is a model listed on Toshiba's website. The Chassis # is - TAC 0302. Your suggestion is to locate an IR sensor part supplier, right ? Do you think it's something I could replace ? Mark
  • Anonymous Dec 01, 2008
    remote will not change channels it is a 35 in tv with model #36A43 # on remote is CT-90157. will start & stop and the volume works but that is all
  • tgronniger Mar 11, 2009
    I have Toshiba model # 36A43, serial # 14843595, chassis # TAC 0302. Have checked the remote sensor, and it lights up with every button pushed. However, even with new batteries, it still will not function tv at all. Can you please Help???
  • 2,322 Answers
If two remotes do not work. I would say the IR sensor on the front panel of the TV might be defective.
Can you provide an exact TV model number to try to locate an IR sensor part suppier?
Posted on Mar 10, 2008
Why has my JMB TV stopped responding to the remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Aug 18, 2014 | Televison & Video
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any...
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Jan 03, 2011 | RCA L32HD31 32 in. LCD HDTV
The TV is not responding to the remote contrlo. It is a new Linsar 16LED05B. We cannot cmplete the initial installation without it. we have checked the batteries and they are fine. The light on the...
is this the second tv in the house? we have just bought another tv for bedroom and had the same problem but we discovered control WOULD function when the aerial was NOT plugged in, it obviously could not tune but all other functions worked. We still have not solved the problem but thought it might be worth you checking,
Dec 25, 2010 | Televison & Video
Battery leaked in my tv remote....changed batteries, clean debris from inside..it is not pretty clean...now it will not turn tv on or off, but will change channels, volume, etc. I just so happened to have...
Probably not, the PCBoard is possibly damaged are the carbonated buttons.
A replacement remote is fairly cheap as is a one for all with the required functions.
Such a waste I do agree.
Dec 02, 2010 | Sony Bravia Remote Control 148016611
Need codes for Innovage Jumbo remote control with a Freeview box.
hi can anyone HELP I HAVE COBOLT JUMBO REMOTE BUT NO CODE FOR ACCER LCD
Dec 25, 2008 | Universal Remote Control Remote Control
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Remote will not work
If the oroginal remote has good batteries but neither it nor a properly programmed universal remote will operate the set, then the little "eye" inside the set could have come loose or just stopped working. If the set was banged hard enough or dropped, a small crack could have developed in the board and cut the lines to the remote eye. This is easily fixed but should be handled by an exerienced tech.
Aug 07, 2007 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Toshiba 36A43 36" TV Logo
277 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
