1995 Chevrolet Camaro Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install tachometer on 3.4 camaro
I have a 5 inch autometer tach. i have hooked everything up correctly(i think). and for some reason i cant get an rpm response. i didnt use the tach adapter because i dont want to spend 80 dollars on one. any suggestions on what im doing wrong. By the way my car does not have a distributor.
jimmy
Level 3:
  • Master 409 Answers
  • Posted on Mar 19, 2010
jimmy
Master
Level 3:
Answers
409
Questions
Helped
146573
Points
1094
Most likely you will have to use the tach adapter to get a useable tach signal from the computer.
Where can i find the rpm sensor on a 2001 ford ranger
There is no tach - rpm sensor . This information comes from the PCM - engine computer .
Tachometer
The tachometer is a 6,000 rpm tachometer. It has four terminals labeled "B" (12 to 14.5V), "S" (EDIS tach signal in), and two "G" (cylinder selection grounds). The top ground (G) terminal is open on a 4-cylinder engine vehicle, and is grounded on a 6-cylinder engine vehicle.
  • The tachometer is inoperative
  • Powertrain control module (PCM).
  • Circuitry.
  • Tachometer.
  • Instrument cluster printed circuit.
  • Go To Pinpoint Test F .
  • Incorrect tachometer indication
  • Circuitry.
  • Tachometer.
  • Go To Pinpoint Test G .
Measure the resistance between the instrument cluster C220c pin 8, circuit 398 (BK/YE), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes GO to G2 .
No REPAIR the circuit. TEST the system for normal operation.
Measure the resistance between the tachometer and the instrument cluster printed circuit terminals; refer to the following chart:
    Instrument Cluster Printed Circuit Terminal Tachometer Terminal C220a pin 13 C220a pin 15 S C220b pin 2 G C220c pin 8 G (6 CYL.)
  • Are the resistances less than 5 ohms?
Yes GO to G3 .
No INSTALL a new instrument cluster printed circuit. REFER to Instrument Cluster Printed Circuit in this section. TEST the system for normal operation. G3 CHECK FOR CLEAN TACH OUT (CTO) CIRCUIT OPEN OR SHORT Check for CTO circuit open or short. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual.
  • Is the CTO circuit OK?
Yes INSTALL a new tachometer. REFER to Gauges in this section. TEST the system for normal operation.
No GO to G4 .
G4 CHECK FOR CORRECT PCM OPERATION Disconnect all PCM connectors. Check for:
  • corrosion
  • pushed-out pins
Connect all PCM connectors and make sure they seat correctly. Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes INSTALL a new PCM. REFER to Section 303-14 . CLEAR the DTCs. REPEAT the PCM self-test.
No The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
Your best bet mite be to take it to a qualified repair shop.
97 cavalier 2.2L OHV, MT ; I trying to install an aftermarket tachometer. Distributorless, two coils mounted, stacked on back side of block. No pos or neg wires to this style of ignition coils. I have...
Who manufactured the tach? Maybe they have a web site and instructions? Did you tach come with instructions?
I looked at autometer instructions for your vehicle, have to use an adapter, it ties into the power wire for your coil pack. The adapter costs about 97 bucks, not including tax.
Different tach manufacturers may have different hook-ups?
My tachometer un hooked and i cant find where to plug it in .... 1991 eclipse gsx thank you
your tach is part of the instrument cluster and if it is not working then you might have a problem with the wiring harness... this will require more detailed assistance than that can be provided for free
if however, you are talking about installing an aftermarket tach, then follow the instructions that came with the tach
Putting in a autometer tach in a 1994 camaro without a painless wiring kit.what color is the negative wire for the tach hook up ?there is three on coil
It should be black,but look on the coil,and it will have a negative sign in the coil next to the terminal like this - Now this terminal,will go to the ignition.
Instaling auto gauge TACHOMETER 3-3/4 INCH in a vw mk1 as per installation instructions but is not working
Check to make sure you are connected to the proper terminals, and that the wiring has no faults from tach to the terminals.
2answers
I have a 1991 camaro and my tach wont work .it tays stuck at around 4500 rpm and goes u from there.is it grounded out maybe?
I had the same problem with the tach on my 92 Camaro. Tried the resistor fix but it didnt work. Finally found a tach board at the junkyard that worked for about a year.
I found a new replacement tach board. Only had it for about a week but it seemed to fix the problem! Hurray!!
NEW 1990 92 Chevy Camaro V8 Tachometer Circuit Board
Where is the wire that controls tach in 1987 Camaro?
If you have the one I'm thinking of, it is just to the left of the main power terminal on the cap (usually marked tach)
Finding the wire that goes to the factory tackometer.
no, you need to buy an autometer tach adapter and tap it in to the harness on the passenger side firewall then run your tach from the tach adapter to your car. Dont mess with the cluster.
go to autometes website and it will tell you how to wire and what pin to splice in. The whole thing will take like 10min to do.
I am trying to install an Autometer Tachometer in a 93 Nissan D21
the signal wire is coming from the distributor under the hood run the wire through the fire wall to that wire and as 4 the wire that lights up the tach piggyback that wire off of the cigarette lighter on the fuse box
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
