Question about VeriFone 250 Matrix Printer
Verifone 250 printing letters and numbers will not stop
I plugged in my verifone 250 printer it has been unplugged for a while, and it started printing numbers and letters seeming to go through a cycle, and it won't stop. I've unplugged and re-plugged, turned off and on, hooked up to phone line and unhooked to phone line. Cannot figure out what is wrong with it.... Any ideas would be appreciated
  • Danny Patel Feb 06, 2009
    yes, I did as per instruction, still problem exist? plz help.
  • Anonymous Mar 27, 2014
    Printing off to the left and jumbled letters
The letters and number it is printing is the self test print mode. Normally to run the self test you would turn the printer off, then hold down the feed button, then while holding the feed button, turn the power back on. It sounds like your feed button may be stuck.
Posted on Mar 28, 2008
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
Need the printer to only print the last 4 digits
To solve last 4 digit issue.
It need to reprogram Tranz 330.
Not buying Printer
this model is not compatible with PCI compliance.
contact your processing company and let them reprogram this.
http://www.gorillapaper.com/verifone-printer-p-250.html
Mar 09, 2010 | VeriFone 250 Matrix Printer
My Omni 3730/3730LE VeriFone printer does not print on the paper
Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper. hope this help
Jan 16, 2010 | VeriFone Omni 3700
Drivers for a verifone 250 printer in winxp
You can try to find it at this link
http://verifone.50webs.com/
Dec 18, 2008 | VeriFone 900 Matrix Printer
I have a VeriFone Printer 250 and the paper will not feed and the power light is blinking....I have turned it off and on and it still does not work. HELP!
I had the same problem - I took out the ribbon and tightened it, put it back in and replaced the cover securely. Then I disconnected the power and turned the switch off. I plugged it back in, switched it on, and the problem was gone.
Dec 15, 2008 | VeriFone PRINTER 250 RS232C INTERFACE
How to "shift" to letters instead of numbers?
Did you try to use the "alpha key"? Press the number key that has the letter you need, then keep pressing the alpha key to get the letter you need.
Aug 28, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Verifone 250
The Verifone 250 doesn't have keys. What are you talking about?
If you mean that it just isn't printing, verify that the ribbon is properly inserted and the impact setting is correct.
May 14, 2008 | VeriFone 250 Matrix Printer
Using a Verifone P250 Printer with a PC Credit Card Program
which one ? i have tried all also the cable i have is a serial 25 pin female so i got a adapter to serial male still wont print can anyone help ?p250 to pc windows xp
Dec 19, 2007 | VeriFone 250 Matrix Printer
Printer will not print
The 1488 And 1489 IC's for RS232 communication are bad. However, this problem can exist in your zon too. So, if you had a known good printer, you could isolate.
Jun 30, 2007 | VeriFone 250 Matrix Printer
VeriFone 250 Matrix Printer Logo
355 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
