Question about Smeg A42-5 Dual Fuel (Electric and Gas) Kitchen Range
Top oven grill element
The grill element has failed, i've purchased a new on put fitting is not as straight forward as i thought any one out there done one and point me in the right direction.
Hey there, Shouldn't be too difficult. Just two nuts to remove. If unsure about reconnecting wiring, draw yourself a little diagram clearly indicating the colours. Let me know if you are having further problems.
Posted on Nov 07, 2008
Fan and element not working
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
Tip
Broiler element does not get hot enough.
I did some work recently on a free-standing electric range.
The broiler element was heating up just a little. It was not getting red hot.
The range was practically new.
I discovered the crimp-on spade terminals to the broiler element had lost their springiness and were not making good contact with the element terminals. The ends of the wires going to the broiler element also showed signs of excess heating due to resistive contacts.
I bought a pack of new, high temperature crimp terminals at the appliance parts store, stripped the wires, and crimped the terminals on.
The original crimp terminals were right-angle. The new crimp terminals are straight. I didn't have a specialized tool for right-angle crimps. The straight crimps worked fine.
Just make sure there's plenty of clearance between the rear cover and the wires coming off the crimps to the Calrod.
Broil element now works great.
By the way, other ranges I've worked on use screw-on terminals instead of press-fit spade terminals. Not sure if press-fit spade terminals hold up after many years of service.
Maybe if an emergency repair needs to be done, could try drilling a hole carefully through the assembled spade terminal and putting in a 4-40 screw to recover the contact without having to buy replacement terminals.
on Jul 14, 2014 | Kitchen Ranges
Hi, I have a Rangemaster 110 (electric double oven), which has a double grill. Unfortunately one half of the grill has blown - not working. Is it easy to repair? Thanks a lot - Krisztina
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
Dec 28, 2010 | Rangemaster Range Cookers Kitchener 110...
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Jul 29, 2009 | AEG U7101-4 Electric Double Oven
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Replaced oven heating element, now trips electric
Disconnect the new heater and try it again , if it still trips then your problem is elsewhere, if it does not trip, then it points to the new element being faulty.
If it is fan assisted make sure the fan is running o/k.
Hope this helps.
Please leave feedback.
Thanks.
Dec 08, 2008 | Ovens
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Smeg A42-5 Dual Fuel (Electric and Gas) Kitchen Range Logo
262 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
