Question about Kitchen Ranges
Electronic Control Panel Problem
Over the years, our oven controls (rubber push buttons activating an electronic control panel behind a glass front) have become more difficult to use. Initially, this happened only during the winter when a bit of cold air came down the exhaust duct. Now, it's a daily problem. Most recently, I've had some success removing the rubber buttons and touching the surface of the control panel with a finger. Now,even that's not working. I almost abandoned my plans to use the oven today until repeated prodding of the control panel with an eraser at the end of a pencil finally worked. What options do we have? Although almost 12 years old, the appliance is otherwise in excellent shape and we'd prefer not to replace it.
Anyone else experiencing this problem might want to try the following. We removed all affected rubber push buttons, exposing the electronic printed circuit panel behind the protective glass. We sprayed a soft rag with "M.G. Chemicals Heavy Duty Flux Remover" and pushed it in each opening in the glass panel, twisting it to clean the circuit panel behind each push button. We then cleaned the back side of each rubber push button with the same flux remover chemical. Since then, the push buttons require the slightest touch to activate. Surprisingly, when pressed firmly they don't work as consistently. We're hoping this is a lasting solution.
Posted on Mar 11, 2008
Lg direct drive start button is not work" what's problem in machine
Take off the control panel. There is a little plastic arm behind the start button that may be worn down on the end and may not be making contact with the electronic button underneath.
To access the control panel on the WD14700RD:
  1. Disconnect the unit from power and water
  2. Remove the top: take off two screws at the back, push it backwards one inch and lift it off
  3. Take out the soap tray and remove two screws on the soap tray compartment.
  4. Remove the control panel: push down on the two arms on top of it so that it can pop out, and pull it out at the top and then lift it off the bottom hooks. Pull it out a little from the machine, about an inch.
  5. Remove the front plate from the control panel: there are 7 screws behind it. Rotate the control panel up or down in order to access the screws behind
  6. Now that the front plate of the control panel is loose, identify the arm of the button that has stopped working. Wrap a small amount (2-3 times around) of electrical or plumbers tape on the very end of the plastic arm. Or if there is a nib instead of an arm, a small dab of epoxy resin allowed to harden does the trick.
  7. Refit the control panel and test the button now works.
  8. Reassemble the control panel, top, and turn on water and power.
  9. Test once again.
And that's it! All you need is a screwdriver and some tape. Too easy. Hope the information helps out.
Sep 17, 2016 | LG Washing Machines
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Error f7 oven wont turn off
Hello there:
The f-7 error code carries several different possiabities
here are several possiable reasons and the things to check
1. F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control)
2.
F7 Shorted touch panel Replace glass panel
3.
Replace clock assembly (also called the ERC)
Please test each of these carefully ok and if you disconnect the board you may want toclean the contacts really good and then try to reconnect the wires and make sure that they are properly connected ok
Best regards Michael
Jan 12, 2010 | Ovens
1999 subaru legacy vent is stuck on defrost
This sounds like the control panel. 90% of the time something gets spilled on the control panel from the cup holders right above, The buttons get gummed up and no longer push the switches behind the button. remove the control panel and dissassemble it, soak the non electronic parts in hot water with light soap, problem solved, My 98 Outback had the same problem.
Sep 21, 2009 | 1999 Subaru Legacy
Electronic oven control broken after 1 year.
replace it and check your ground try to touch the stove before you set the control panel to remove static charge(and yes I do have my suit and tie on)
Aug 18, 2009 | Whirlpool GY396 Electric Kitchen Range
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Ge range model #JSP42BK4BB
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
These are the codes for ge depending on the model.
Oct 26, 2007 | Kitchen Ranges
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
284 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
