Hi All,
We are a workshop in Spain & I have had several problems with "Down grading" to XP. There is essentially one problem which causes an issue with the XP installation & that is if the the BIOS has a "Fixed" sata configuration. By that I mean you cannot change it to some sort of IDE or P-ATA (Symantics). Our current problems are with an Acer 5720 & an HP Pavilion DV9700. The Acer solution is exactly as "
kraken3000" had mentioned before:
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
DONOT set this back to SATA Mode after you install the XP as it will NOT boot. This setting must be kept untill you "Upgrade" (If ever) to Vista. The HP is another story...
Visit the Acer Panam site & download & install the XP drivers & your good to go...
I hope that this was of help...& good luck folks
