Question about Sony PlayStation 2 (PS2) Console
Controller Where do I get replacement rubber pads for the analog sticks?
  • 40 Answers
As to my knowledge you need to get a new controller, rubber pads are not sold.
Posted on Mar 10, 2008
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
Problem with logitech dual pad right analog
Try to disassemble the pad. Reseat the analog stick and re-assemble the pad.
May 12, 2012 | Logitech Dual Action for Pc (963292-0403:)...
My lbp character wont move, when i try to walk the Right arm is only moving? Hos do i fix it?
It sounds like you may have a problem with your controller. Pressing the L2 button and moving the left analog stick, which also controls walking, will result in SackBoy moving his right arm (left as he's looking at you.) If your button is stuck, it will override the walking function. Try holding down the L2 button and releasing it rapidly. Hopefully this will snap back the rubber contact pad back into position. If this doesn't work, try a different controller if you have access to one. As a last resort, you can try disassembling the controller, if you feel comfortable doing so, and making sure that the contact pad is in correctly and not bunched up and also that the return spring has plenty of bounce. Hope this helps. Have a good day!
Jun 08, 2011 | Video Game Consoles & Games
AN IDIOT FRIEND PRESSED WAY TOO HARD ON THE ANALOG STICKS AND BROKE THE TOP PLATE OF THE CONTROLLER WHERE THE ANALOG STICK IS. THE ANALOG STICK IS EXTREMELY LOOSE AND PRACTICALLY COMING OUT OF THE...
you could get an old faulty controller off ebay for cheap or out a second hand shop for cheap and just replace the top plate fiddly as anything tho.
Feb 02, 2011 | Sony Dual Shock 3 Controller for...
When I push my right analog stick to the left, the screen keeps moving even when i don't move my analog stick. Is there something wrong with my controller?
Theres might be a problem with the controller. You can open the controller check the rubber and clean it or it it still has a warranty you can ask them to fix it or perhaps replace it.
Thanks for using Fixya.
Jan 31, 2011 | Microsoft Xbox 360 Controller
I play Call Of Duty Black Ops and You usually need to sprint by pushing in the Left Analog stick and your direction. For some reason my controller is pressing multiple buttons when I push the analog stick...
You have a couple of options here. Sounds like your controller may be on the fritz, so if you have the money, I would suggest purchasing a new controller.
Otherwise, in the game options, you can re-map any function to another button on your controller. I would recommend remapping the sprint button to some other button that you don't use for that game.
Dec 10, 2010 | Sony Playstation 3 (PS3) Console
Issue with right analog stick - Xbox 360 Controller
I'm afraid I've had the same problem and I can shed a little light on it.
I've tried to fix this but to no avail. I have even transplanted the whole analog stick unit with one from a working controller to see if it will work but I have the same problem.
So, my conclusion the problem is not with the stick itself, but with the microcontroller inside the pad which takes the info from the stick.
I took the analog unit out, and plugged the pad into the computer without it , but STILL the vertical axis on the right stick was pushing up even though there was no input from a stick. It seems to be a fault with the pad, not the analog stick.
Aug 21, 2009 | Microsoft Xbox 360 Wireless Controller
On the home page controller keeps moving up but this does not happen during game play
Is this a dual shock controller or a computer controller? Dual shock controllers sometimes have sticky pads or the analog stick are looose, on a computer the controller may need to be calibrated.
Dec 11, 2008 | Video Game Consoles & Games
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
