Question about Philips 50PP9202 50" Rear Projection Television
Further details What's next after IC's replacement?
    Genius:
  • 1,694 Answers
Check resistors near IC's for burn or over-heating.........T.
Posted on Mar 19, 2008
No power i replaced already the power IC till no function
What is the brand name to your TV? Without any detail, how can one post a solution to the problem you faces? Which IC did you replaced? What was the problem you did face, before you replace this regulator IC? If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 22, 2015 | Televison & Video
KV-F29MH31
horizontal IC problem
just replace it sir
Apr 21, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Next crttv TDA9370ps/n3/3/0960 Standby mode I replace Eprom ic
Try by replacing its main system memory IC. It is a very small IC, have 8 solder terminals, and can be located very near to TDA9370. Be sure to replace it with the same number printed on it, otherwise wont go. It is a very cheap one to buy. If it do not help you, replace the TDA9370. Failure rate to this jungle IC is rare. Check all the related components, and make sure that all of it are OK, beofre replacing TDA9370. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
Univerum tv control memory ic
You have to initiliaze the TV, after memory IC replacement. For more details, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | Televison & Video
No Sound on AM or SW
Hello
If the set receives FM signals without any problem, and only fails to receive AM signals, the IC [integrated circuit] used in it is faulty. The number of the IC used with your radio is CXA 1376AS. It is a replacable type IC, and can be bought from most of the electronic spare part shops at your town. If you want further details about its service manual, get me by Fixya. OK.
Nov 11, 2011 | Sony ICFSW7600GR FM Stereo World Band...
Rca f20517wn has sound but there is more noise than sound. it sometimes has a problem with the picture drifting into horizontal lines. please help.
Play a external device such as X box or DVD player. If the problem persists, this would confirm that this is an internal failure and needs repair. If the TV is less than 1 year old, you need to call the manufacturer to get it replace / repaired without any charges. However, if it is more than 1 year, then repair is the only option.If you have experience in repairing TV or electronics, revert and i would be able to provide few more inputs that would be helpful in repairing this. Unfortunately, this is not an easy fix as there are many things that could cause the issue you mentioned above.Most probably there are 2 issues here - either a power supply board or main board or both. Most often the symptoms you mentioned point towards main board, however without testing and diagnosing, it would be difficult to predict the exact problem.
If DVD player or X box console works fine, then the issue is either with cable or external factor. Then, we need to check all the connection details to find out the cause.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 20, 2011 | Televison & Video
Toshiba, 36A50 picture is a thin white line. Can this be repaired?
Yes...this TV may be repaired. The line you describe is in the center and is horizontal across the TV. You will need to resolder the vertical IC pins. This vertical IC is mounted on a large heatsink. Under the board you will see there are 5 or 7 pins that will have rings around them. Resolder these. And you should replace two or three capacitors that are next to this IC. A bad cap will overheat an IC and separate the solder grounds. If you can find my expertise page on this website, you will see the repair in more detail. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Toshiba 36A50 36" TV
I have a mitsubishi vs-4541/4542 tv with sound and no picture. What are my options?
I have not repaired this particular model. If this TV is a projection set,you have one of two possible problems. First....You may have convergence IC that has lost a ground contact to the signal board. We are discussing the board that has all your RCA connections and RF connectors. You may have to replace, possibly a STK-XXX series convergence IC. One or two capacitors near this IC, usually a bad cap will end the life of an IC and resistors. And replace a couple of resistors, these are standing tall next to the convergence IC. The next problem could be on the power supply. The power supply will almost always have the flyback transformer on it. If you can locate the vertical IC..This IC may need resoldering. You will see rings around the pins of the vertical IC. Replace the three or four capacitors next to the IC. A bad capacitor will overheat an IC and cause solder grounds to separate. Thanks for asking and show a few hands of support!
Dec 09, 2010 | Mitsubishi Televison & Video
Same Problem! Sony Z1 turns off and back on as it wishes and it is not recognized by my comp. I've tried other computers, cables, everything but no luck! Is there any think I should try before heading to...
Hello, I'm afraid your iLink IC is the problem. Unfortunately it is a BGA device and resides on the very expensive VC367 board. Sometimes the IC can be replaced albeit with very specialised IC removal equipment or the board needs replacing. This is also specialised in that all the Z1 data is stored on this board requiring the data to be, first, downloaded to a PC and then uploaded once the new board is fitted. The camera then needs aligning.
Contact me for further details.
ianmcgirr@yahoo.com
Sep 05, 2009 | Sony HVR-Z1 Mini DV Digital Camcorder
No sound
Your camera needs audio/video chip IC replacement. further details can be provided if you know basic electronics and have proper tools for replacement of chip IC.
Jul 10, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Philips 50PP9202 50" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
