Question about Refrigerators
UNABLE TO FIND ICE CUBE TRAYS THAT WILL FIT INTO A MODEL NO. FR331 / FR331B REFRIGERATOR, CAN YOU DIRECT ME. JOE BAGLEY joebagley@comcast.net
  • Refrigerators Master
  • 19,396 Answers
Which is fridge make and where are you located?
Here is general spare parts finder
here is spares for uk
Posted on Mar 10, 2008
    Brigadier General:
  • 3,614 Answers
The ice cube tray won't fit can you or how do you adjust the cifiguration of the freezer comaprtment to allow it is a bottom kitchen aid freezer
This is a common problem,Throw the tray in the bin and buy ice cube bags from any supermarket. You will produce a lot more ice and bigger cubes.
Regards
Steve
Jul 22, 2010 | Refrigerators
Frigidaire model PLHS237ZDBA Ice maker dispenser won't switch back to cube ice it keeps crushing ice though its on Cube ice?
The rod under the ice tray was not in the correct position when the tray was inserted back into the freezer after removal. I get cubes now.
Feb 08, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
Regrator ice crush not working.The next water is working and all good
Make sure the Ice Maker tray is fully inserted and correctly.
Did you hear any huming sound?
If you do, remove the dispenser tray empty out the ice cube and deforst all the ice that stock in it.
Put back the ice cube and try it.
nguyen@ite.net
Jun 09, 2009 | Refrigerators
U-Line clear Icemaker clr2160 cube shape
Hi Joe
That is normal. You will get that dimple because the grid is shaped that way. You can try adjusting the thickness. Hold the up arrow then press the down arrow 3 times,then release the up arrow last.You should see a number 0-5 or 0 to -5. when that happens use the up arrow to 3 then press the light key. This should take it back to ice on the display. Wait 24 hours and check the ice.
Apr 06, 2009 | U-Line Refrigerator Ice Maker
Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA
If the auger motor turns in either setting we know that the auger motor is OK, and if it does not turn in both crushed and cubes that leaves a problem with the WR55X129 time delay, which is the part that you switch to go from cubes to crushed to water.
Dec 06, 2008 | Refrigerators
GE Refrigerator slow to make cubes
I had the same problem with mine a month ago. The plastic feed tube to the water solenoid valve was cracked and letting a large portion of the water go under the fridge on the floor. I just cut the cracked tubing off at the valve/fitting area and inserted good tubing into the fitting and tightened it up, it has been perfect since!
Dec 05, 2008 | Refrigerators
Ice Maker
Put less water into the ice tray.
Sep 23, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice maker for Model HSS25GFPJWW
Probably, but sometimes frost builds up in them and makes them unable to turn. They are gear reduction motors so you may not be able to turn it by hand, but if you take the ice container out, hold the door open, the door switch closed and press the ice dispenser and try to turn it whichever direction it's trying to go, you may be able to free it up. If that doesn't work you'll most likely need a new auger motor.
Jul 21, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
