Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Heat Element Won't Turn Off
After using the microwave feature, the door was closed and we noticed the upper heating element light up bright. When door opens, element goes off. When door is closed element comes on and stays on. Rechecked all keypad settings and unplugged it for a while, but problem still exists after resetting.
  • Anonymous Nov 20, 2008
    The microwave just started to run without any
    assistance from me. It hadn't been used all
    day. I tried to turn it off, but it kept
    on running. I ended up unplogging the unit and have
    called GE to repair this unit. I have no idea what this will cost me.
    Greatly disappointed. It is only three years old.
3 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: manual
If the actual model number is SCA1000 then you can find the manual online here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=SCA1000DBB If that URL doesn't work, here is the compact version: http://tinyurl.com/yarzau If your model number is different, you can enter it here: http://www.geappliances.com/service_and_support/literature/
Posted on Oct 28, 2006
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 31, 2009
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 27, 2013 | GE Microwave Ovens
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium 120 . The panel lights up I do not get an error code the timer works but it does not heat up. what could cause this
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Jul 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave not heating every time...
You seem to be having a problem with the interlock device. when you close the microwave door it is supposed to hit a series of 3 switches to tell the microwave every thing is safe and able to run. you may want to take the control panel off and make sure those switches are ok. usually out of the 3 switches top and bottom should be open middle should be closed. you could check with the continuity side of your electric meter.
Let me know if you have any questions before rating me.
Nov 15, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
151 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
