Question about Epson Stylus C84 InkJet Printer
Epson c84 ink cartrages
Hi ,i just replaced all 4 ink cartrages but the yellow and magenta are not printing. what shoul i do?
thanks
    Sergeant:
  • 390 Answers
Hello Carla, can you manually clean the heads where the ink delivers the printer. Try using the printers own program first then do a manual clean with proper cleaning solution if this will not work.
Posted on Mar 11, 2008
Two Cartridges of 4 Not Recognized (new, empty-chipped)
No matter what you do, it will not recognize it.
Brother and Epson's require original epson ink.
Good Luck.....
Nov 19, 2009 | Epson Stylus C84 InkJet Printer
No yellow
buy a new one srry man if u eney thing els tell me at alexswierenga@yahoo.com
May 29, 2009 | Epson Stylus Pro 7600S InkJet Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Magenta ibk problem
Have you tried running head-cleaning cycles? If not, try 2 or 3 followed by a nozzle check and see if magenta starts to appear. If this still produces no magenta print, or you've already tried this with no success, report back.
Feb 01, 2009 | Epson Stylus C84 InkJet Printer
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Flashing Red Lights
it means that some time you are using low quality ink
or the paper not loaded correctly
thank you
Jan 11, 2008 | Epson Stylus C84 InkJet Printer
Printer does not print
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Jan 06, 2008 | Epson Stylus C84 InkJet Printer
C84 printer
Thanks for reading!
Dec 07, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
154 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
