Samsung Monitor resolution reset to 800x600
I have a Samsung SyncMaster 225MW Monitor connected to an HP Slimline Desktop PC running Windows Vista Home Edition. The recommended max resolution for this monitor is 1680x1050. After each re-start or user account change, the resolution is reset to either 800x600 or something in between that and the max. resolution. Randomly and after quite a bit of monitor flickering. System tells me I am using an ATI Radeon HD2400 graphics card and I am using ATI Catalyst Control Center SW for the settings. Any idea how to fix this annoying reset of the monitor resolution?
Thanks for your support :-)
  • Marcel Nussbaum Mar 12, 2008
    Thanks chrisson, I tried that, unfortunately without any success.
    I might have to wait for a 1.1 version of the Samsung driver for Vista.
  • 22 Answers
I think you have problem with your graphics card. restart your computer and then before starting to windows press F8 to set your settings to safe mood, after booting up to windows restart the system again.if the problem persist reinstall the software drive of your graphics card if you have it.
Posted on Mar 12, 2008
Samsung CRT syncmaster 1100p shows backgrd pic when tested with laptop link, but gives no display when connected to desktop where it has been running for years. This after an internal dustclean and...
At first check your CPU that it is working or not by connecting another monitor. If working then then right in desktop-->Screen Resulotion-->keep it 800X600 -->OK--->OK.(in windows 7 or latter )
then reconnect with your monitor it will work.
Sep 13, 2017 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
Nov 21, 2010 | Samsung SyncMaster 2233SW Monitor
I switch my monitor from a 17 inch to 26 inch but on the new monitor its still at the 17 inch instead of the 26 inch
Change your video resolution to match the new monitor. Right click in a blank area on your desktop go to properties and change your resolution (in XP). In Vista or Windows 7, after right clicking on your desktop, choose Screen Resolution (about the 3rd one up from the bottom of choices).
Oct 17, 2010 | HP Hewlett Packard Pavilion Slimline...
Plug in the monitor and it comes on momentarily but then cuts out to blank screen.I got this given to me and am just trying to see if Ican use it with my hp system thanks.
Hi. If the display goes out after displaying the Power On Self-Test (POS) and the power indicator turns amber, it means that the display resolution of your computer is higher than what SyncMaster 192S can handle.
If you still have the monitor that you were using before, connect that one and change screen resolution to 800x600 and 60 Hertz. Turn off your computer then change monitor/LCD and turn on your computer. You may change screen resolution to optimize display on your SyncMaster 193S.
Let me know if you need help changing screen resolution or if you don't have the original monitor that you were using on your HP.
Aug 18, 2010 | Samsung SyncMaster 193S
I have a Mag Innovision 2200W Monitor. I messed with the settings, and now I get a ''mode not supported'' error. The computer is running in the background, and works with other monitors, but not this one....
Hi
To resolve this issue connect a monitor which is working with the Computer. Now right click on desktop and select properties(if windows XP) or personalize/screen resolution (if windows vista / 7)-> Now click on settings tab (windows XP) or change the resolution of your monitor-> Choose a lower resolution rate maybe 800X600. Now try connecting the other monitor with your Computer and it will work.
If not then check for the refresh rate of your monitor, adjust it to 60 Hz. You can adjust refresh rate from settings tab->advanced button(in XP). Screen resolution/Display settings(under windows 7/vista)->Advanced setting->monitor tab ->refresh rate.
This will surely resolve your issue.
Daniel Scott
Jun 08, 2010 | Computers & Internet
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
SYNCMASTER BM SREEN WILL NOT ACTIVATE JUST A FLOATING SQUARE BOX SAYING NOT OPTIMUM MODE RECOMMENDED MODE+ 1280x1024 60hz analog
I tried the following options and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I didn't have another monitor handy to swap out so I had to be a little more creative. The only solution that worked for me is re-booting (F8 during startup) into the mode "Enable VGA Mode". This allowed me to go into the normal desktop with a screen resolution of 800x600. I went online, found the driver, downloaded it to the desktop. Deleted the video driver (Device Manager), installed the downloaded version, rebooted and....no problems.
I have Windows XP. Hope that helps. :)
Jun 06, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Not optimum mode
This means your computer windows resolution is not display in the correct resolution which your samsung LCD will take.
What you need to do it boot the computer in safe mode. (pressing F8 at start up and select safe mode) This should bring the windows to start up in the generic 800x600 resolution.
Once you are able to see the display in safe mode, go onto the display properties and change the resolution.
* right click on desktop -> properties -> settings
Please rate this if it solves your issue. If you need further assistance please post.
May 29, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Computers & Internet Logo
1,295 people viewed this question
David Payne
David Payne
