If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Your TV has the fault. The blinks you see with it are called blinking codes, and are fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV, which will make repair easy. If you're sound in electronics, and have all the tools to work, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
These blinks are fault indications, and are called blinking codes. Count the number of blinks occur at one time switch ON. By these blinking numbers, you can get an idea about the faulty circuit stage inside the TV; which will make repair easy. If you're sound in electroncis. and wish
Blinks of power light indicates fault. These blinks are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of blinks occur at one time switch ON, and check the site linked here for more details. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
The green LED is called the memory acces lamp. When you switch off the camera is will write back the last changes. when you switch the camera on and off, the light ususaly will stay off, because nothing has changed. When you remove the card en put in another the LED will flash again. At least my D7000 with 2 card slots will do so, because someting changed and the system will write that into the memory.
hi :)
the phone no display but still get incoming call ??
if still,maybe the phone LCD has spoil or the LCD conector has been bad lift.
if cant receive incoming call,please focus check on the display isnt have blinking when u switch on,if have mean phone software has been corrupted.
u need to reload phone software.
please voted me if my solution useful,thank.
sir, my sigmatel s90 phone had gone to flight mode but after putting a code it display some options ,i select one of them and it goes to switch off and on switching it on its keypad just blink pls help me
I try your solution but no effect say any other solution
