RED CONVERGENCE STILL OFF
REPLACED BOTH STK'S RED CONVERGENCE STILL OFF. WHAT ELSE COULD BE THE PROBLEM? PLEASE HELP CUZ IM NOT PAYING TO GET THIS 5 YR OLD PANASONIC FIXED.
  • 2,326 Answers
Next step should be to check the fuse-resistors and low values resistors for open conditions as well the solder joints on them.
These parts are located near the STK ICs.
Also if you can measure the voltage that power up the STK's. If you do not have the schematic diagram, check the ICs data sheet to know where the voltage is getting to the ICs.
You may have to do the convergence adjustment manually after you replaced those parts.
Good Luck.
Posted on Mar 10, 2008
I have a 12 yr old Mitsubishi projection tv model vs 60607 with a red/blue convergence problem. Can it be fixed?
It should be fixable----this model uses two of the STK-392-110 chips for convergence.
If it adjusts but will not remember the adjustments either a bad solder connection on one of the chips or a problem with the DCM---digital convergence module which stores adjustments.
Adjustments in customer menu may not be being stored--
Jun 10, 2012 | Televison & Video
I have a Magnavox 51mp392h/17,that now has double vision (text is double,all images) there is also green, off red colors on the picture. Please help me the tv is 6 years old. should i throw it away or get...
No.Should cost u like $300-350 for parts and labors.Get it fixed any local tv shops can fixed this problems,very common problems for DLP CRTS tubs design projection tvs Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture colors lines R,G,B mis alignments,have pictures colors shadow or 3D pictures look alike.The tv convergence board must have it parts replace like 2 STK convergence ICS and some or all of it resistors to fixed the convergence board to solved convergence pictures problems.
Jul 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 10 year old tv goes off after about 5 minutes and the blue
Any colors mis alignments R,G,B.The tv have a problems known as convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
PANASONIC PT-46G40U CONVERGENCE PROBLEM HELP...
Have you checked the bias resistors for Exact Value. They normally change value when the stk's take a dive.
Dec 09, 2009 | Panasonic PT-46G40 46 in. Rear Projection...
I have a Panasonic 53" projection tv approx 4 or 5 years old. I have double images what is the problem?
Convergence problem.
Replace STK 392-110, check any resistor around stk.
Thank you
Aug 05, 2009 | Panasonic Televison & Video
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Panasonic Projection TV PT-47WX49E convergence ...
may not be convergence may be a bad stk for convergence if that style if so try stk
Oct 28, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Help- picture
yes,this can be fixed for $ 280.00 - $350.00 depends on your area,you need to replace STK-392-110s both stks then do complete realinement of convergence. set fixed!!!!
Oct 17, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
