Question about Meiko FV 40.2 Dishwasher
Meiko FV40.2 Error codes
Hi ,I've gotten a new error code not listed in my manual. it is code 312. Do you know where I can get a full code list?
Thanks D1000
    Problem Solver:
  • 11 Answers
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Posted on May 10, 2008
  • Sam Zeiber Feb 02, 2012
    The error 312 is not the same as 212. It is similar, but it is referring to the wash tank temperature being too high. The error 212 indicates the booster/boiler temperature is too high. If the contactor K2 is not stuck closed, then most likely you will have a faulty temperature sensor. If you take a resistance reading of the sensor, you should read around 1000 Ohms at room temperature. There will be a little tolerance difference but nonetheless you should be within 5% of 1000 Ohms. At 180 degrees, you will read around 1500 Ohms +/- 5%. If you are out of this range, replace the wash tank temperature sensor.
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
What is Error Code H44 on Panasonic Washing Machine?
sad to say there is no H 44 listed o the 4 places I looked
Jun 17, 2014 | Washing Machines
I have a Cash Register Casio TK-3200 and I am getting error 15 and is not listed in the error listing.. how do I fix it ??????
Hi Luis - Error code 015 refers to Receipt Paper End.
Error code 014: Receipt paper end (1/2) RECEIPT PAPER EN (plain English message)
Error code 015: Receipt paper end (2/2) D
There are several versions of the TK-3200 manual but this one lists the error code you want:
http://www.salopcashregisters.co.uk/pdf's/TK-3200.PDF
Aug 04, 2013 | Casio tk-3200 cash register
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
Technika video DVD player error code 03 will not allow me to turn the player on
Error codes and their meanings will be listed in the instruction manual.
If you've no longer got that go to Technika's website. In Customer or Technical Support (or whatever they call it) you'll be able to get a download of the manual.
Sep 24, 2011 | Televison & Video
SC685 on Ricon AP3800C
Nothing official listed for this error code. The SC6xx are electronics related errors.
If there is a HDD, try disconnecting it.
Otherwise, you may have a bad connection to the main electronics board (BCU) or a bad BCU.
Sep 15, 2009 | Ricoh Aficio Colour 3006 Color Copier
60.40 Error Message on HP Laserjet 5025 MFP printer
Hi
Welcome to Fixya
Have alook at the webpage by following this link:
http://servicelineat.ro/hplaserjetm5025.html
Scroll down the page for error listing. Unfortunately error 60.40 is not listed. It may help to ring HP service centre for a full error code list.
Hope this helps. Please don't forget to Rate this solution.
Thank you.
Feb 23, 2009 | Minolta EP1083 CS/PRO Copier
DFI LanParty DK 48 Motherboard, LED Error Code: 88? Does not boot, LED displays 88.
From the manual - Code 88 is "There is no "88" definition on the Award BIOS code. (BIOS program executed the wrong process therefore showing the wrong POST code.)
1 of 2 problems:
1. The BIOS - Mixed-up BIOS data, which is fixed by resetting CMOS information
2. MB is defective. (NB chip may be defective.), which you have to RMA to manufacturer
Oct 22, 2008 | Computers & Internet
Error code f-20?
dmary, if this is an Oasis dryer, F-20 is the code for a shorted #1 element. They forgot to to list it on the tech sheet. For your techs general info. F-21 is a shorted #2 element. Catriver.
Sep 10, 2007 | Kenmore 67082 Electric Dryer
Dishwashers Logo
4,235 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
