Question about OKI MICROLINE 320 Turbo Matrix Printer
Changing the paper lever
How do I change the Paper Lever on Oki 321 Turbo? Do I need to take other parts out before taking the paper lever? Is there a specific position that would be best to take it out (Front- Middle or back)?
can you point me to where I can find the service manual?
Many thanks
One of the first things is do a search on internet for a service manual.
http://search.yahoo.com/search?p=user+guide+ML+320+%2F321&fr=yfp-t-501&toggle=1&cop=mss&ei=UTF-8
Posted on Apr 09, 2008
Oki 321 turbo,printing goes too far on left side
Not usually, Go through the paper park, where does the head stop when you turn it on. There is a switch in the base of the machine...
Aug 01, 2016 | OKI Office Equipment & Supplies
OKI MICRO LINE 321 TURBO REAR FEED PROBLEM
Have you tried taking out the Platen Roller (big smooth one) and washing it??? Soapy water is fine as long as you rinse & wipe it down to get the soap off... Sometimes the platen rollers slip when dirty and they can cause similar jams.
Oct 17, 2014 | OKI MICROLINE 321 Turbo Matrix Printer
Printer epson lq 2070 this printer are giving error paper out error linking the led
You may have tried to change the paper release lever position while paper was still in the printer. Return the paper release lever to the original position and eject the paper. Then change
the lever position.
Check that the printer cover is closed properly.
Feb 22, 2011 | Epson LQ 2070 Matrix Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
We print a 3 part Invoice and the print on page 2 & 3 are so light you can hardly read them.
On the left side of the ribbon holder is a blue lever. move this towards the paper (rear of the printer) until you get clear prints
Dec 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
When printing onto forms streaks from left to right apper on the printed words
I think the printhead is to close to the paper. You can set it by moving the small (blue?) lever on the liftside of the ribbon
Jan 06, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Installed a new okidata microline 320 turbo dot matrix printer and now the tear/set button does not set the paper where i need it to as my old printer did. How can i change the tear line setting?
Make sur that the paper length is correct in the settings. With paper in the printer hold down the "SHIFT" button then press the "SEL/MENU" button. The "SEL" indicatr will light up. Now press the "PARK" button, a settings page will print. Select your paper length you require by going through the settings, if you press the "LF" button it wil take you through the different groups of settings, the "FF/LOAD" button wil take you through the different items in the groups and the "TEAR" button will change the settings on the different items. To save the new settings hold down the "SHIFT" button and press the "SEL/MENU" button.
Aug 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Light print out
Hi, before buying new bits, make sure that the position of the printhead is near to the paper, there will be a 'head gap adjustment lever. hope this helps
Feb 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline 420 Network Card
As the alarm is on and steady then you most probably knocked the change lever into a position where it detects no paper loaded. The easiest way to check is to load your paper and move the change lever until the error lamp goes out!
Sep 08, 2017 | OKI MicroLine 420 Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
93 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
