Question about Hotpoint WMA64 Front Load Washer
Just moved filled machine, tried to set, goes to wash then to e 13 or e19 please help
    Problem Solver:
  • 10 Answers
E13 code means Pressure switch Fault
To check :- Remove Plug First ( Remember Safety First )
The pressure switch is at the top, its move likely to be a blocked pressure bottle, which is under neath the tub accessed via the rear bottom access panel 3 to 4 screws. the bottle is on the side of the filter with a small clear tube going up to the pressure switch. Clean this bottle out.
E19 code means Power Failure during Programme
Posted on Mar 19, 2008
Hallo i have an aeg washing machine made in the netherlands and is showing e19
I looked up the list of error codes for this washing machine and sorry but e19 is not listed, it skips that one number. Please contact AEG.
Jan 25, 2017 | AEG Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
THE WASHING MACHING FILLS WITH WATER, GOES THROUGH
Most Likely it's the timer. try to move it by hand to the net cycle. If that doesn't work it's the contacts on the inside fouling up.
Sep 06, 2009 | Whirlpool Washing Machines
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
13 month old kenmore 48112/48116
lights are flashing and beeping while not running any cycle.. Please help.
Dec 20, 2008 | Washing Machines
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Hotpoint WMA64 Front Load Washer Logo
225 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
