Question about Cyberhome CH-DVD 300 DVD Player
Getting it to turn on.
The player won't turn on, wont eject the disk tray, nothing. When I plug it in and press power, it does nothing. What could I do troubleshoot the circuts and player in general to fix it. I don't want to buy a new one, cause if I can fix it, I get it for free. Thanks!!
  • 2 more comments
  • ImBlueAngel Apr 22, 2008
    I have the same problem. The red light is on, it is making noise, but the green light won't turn on.
  • Takusan Jun 09, 2008
    When I insert DVD, the screen come out say that no CD, or bad CD etc. and can't display. I do not know what is caused this problem, since It works well before. Please help and teach me how I can fix it.
    Thank you for your time and attention. I am looking forward to hearing from you as soon as possible.
    Comment by Takusan, posted on Jun 08, 2008 Today I tried again to see if it work but t became entirely nothing work even I try to turn on power, and see nothing come out on TV screen, and light is still keeping on red. Those things of problem and truble to let me dubt that Cyberhome CH-DVD 300 is certainly not a good product. I am regreting that I bought this bad product of Cyberhome CH-DVD 300. Help, please
  • TickedOff54 Jun 16, 2008
    Cannot turn unit on at base or remote. At base, green light comes on for a second and then goes out. No red light at all. Can't open door ...
  • Anonymous Jun 19, 2008
    after dvd disc inserted, press play, usually green light comes , but no green light and can't take disc out from the player. I can only see Cyber home on the tv. screen, but do not advance further, please help me.
Ok i had this same problum and all u do is if there is a disk in there good.....bug if not open it from the bottom opener just slide something over in the slot put a disk in there and move the lins(you will have to remove the cover) and it should start working
Posted on Apr 21, 2008
    Master:
  • 518 Answers
I would start by checking power supply voltages and fuse(s). Also do a good visual check of that area.
Geno
Posted on Mar 10, 2008
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My cd doors wont open what can do.
Hi.
Try disconnecting power. Connect back and then turn the DVD on by using the button in the player (not the remote) while at the same time you keep pressing repeatedly the eject button on the player. You will need to keep pressing eject until the unit start loading the disk.
If that does not work, then the DVD must be disassembled undoing the screws holding the top cover in the chassis.Once disassembled there is usually a disk stuck inside the drive or a mechanical issue. The disk tray motor rarely fails.
Do not disassemble the player unless you have repair experience. Before proceeding check warranty status.Call Kenwood if you want to book a repair
Regards.
Ginko.
Feb 03, 2011 | Kenwood CD-223M 200-Disc CD Changer
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Tray not ejecting
check the door belt wich is placed underneth of the driv mechanism.if the belt is not broken or getting loose in size then check the motor pully then motor. best wishes do with care.
Jun 14, 2007 | Akai DVDS3500 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
70 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
