Motor part number/ tourque settings
I need a motor prt number or some torque values of the motor on the right middle motor that powers the front paper feed bar. this motor burned up and my boss is on my case to get a new motor for it. having a hard time findind schematic's for it or anything.. any suggestions?? ( he wont buy a new one . its a " test of skill "
  • 1 more comment
  • Curtis Callaway Mar 10, 2008
    sorry i typed the model number up in the subject area,. the printer is a lexmark x8350 the front paper feed electric motor i have the motor extracted from the machine but there are no part numbers on it. ( go figure ) thax for the help
    printer scanner -copier, (flatbed scanner)
  • Curtis Callaway Mar 11, 2008
    naw. i found the part nubmer and contacted the manufacturer, they have it posted on line. but unfortunatly they do not make this motor ( im sure they do ) anymore. and have stop producing the printer.... i knew this allready so i had my boss make the phone call and after having to wait 20 min for that answer he's sorta said ***** it.. :d go figure :-) thanks for your help tho. hope you ahve a great day.
    Genius:
  • 3,587 Answers
Of course, with a model number, this enquiry would be most effective, no?
Posted on Mar 10, 2008
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    ok...so you want to replace that motor? is it tight or otherwise out of kilter(bearings?)>
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    not to worry. thanks for the update..and perhaps you'll rate this one when you're done...
I need the head bolt tourque for a 2001 5.4 l ford
The picture is an example of torque sequence.
First step--30 ft lbs
2nd--turn additional 90 degrees
3rd--turn additional 90 degrees.
The number one bolt you tighten first is outside middle on either head. The even number bolts as far as tightening, are on the inside of head. The odd number bolts are on the outside, as far as tightening. Inside and outside relative to engine.
Oct 09, 2017 | Ford Cars & Trucks
Clutch tourque specs
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Ducati despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
torque values for clutch hub for 749 Ducati ms The Ultimate Ducati Forum
Torque Settings Engine ducati org forum the home for ducati owners and...
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 22, 2013 | 2003 Ducati 749
Clutch tourque
Hi, Anonymous for more information about your question and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Ducati Maintenance
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2¼-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
ii
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
ILLUSTRATIONS ¦ FIGURES ¦ ILUSTRACIONES¦ ILUSTRA??ES
Removable tab
Languette
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
English
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
GETTING STARTED
OFF ON PRT IC GT
POWER
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
position.
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
calculator.
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
SELECTION SWITCH SETTINGS
OFF ON PRT IC GT
POWER ROUND
: 5/4 9 + F 0 2 3
DECIMAL
TAX
SET CALC
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
SWITCH SETTING FUNCTION
POWER ON
PRT
IC
GT
No printout is provided; however, the display can be printed by pressing
4.
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
5/4
9
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: :
DECIMAL: 2, TAX: CALC
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: 5/4
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
TAX SET
CALC
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Setup: PRINTER: PRT, DECIMAL: F, ROUND: 5/4, TAX: CALC
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
KEY DESCRIPTIONS
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Ex.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Answer:
Selling price: 990
Gross profit: 396
Ex.
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Answer:
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
I need the torque settings for avw passat 1.9 tdi ajm engine cilynder head bolts
WELL YOU DID NOT GIVE ME THE YEAR AND MODEL OF YOUR CAR. WHEN YOU TORQUE THE HEAD BOLTS YOU WILL MAKE 4 PASSES. FIRST PAST 30 FT LBS / SECOND PAST 44 FT LBS / THIRD PASS PLUS 90 DEGREES / FOURTH PASS PLUS 90 DEGREES. YOU NEED TORQUE SEQUENCE GET A PIECE OF PAPER FROM LEFT TO RIGHT WRITE NUMBERS 10 4 2 6 8 ON THE SAME PAPER WRITE SECOND ROW OF NUMBERS UNDER THE FIRST I GAVE YOU WRITE NUMBERS LEFT TO RIGHT. 7 5 1 3 9 THOSE NUMBERS I GAVE YOU IS THE BOLT LOCATION YOU TORQUE HEADS USING THOSE SEQUENCE NUMBER TO TIGHTEN CYLINDER HEAD SO YOU WONT BOW THE HEADS.
Nov 13, 2010 | Volkswagen Passat Cars & Trucks
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Oct 18, 2009 | 1994 Jeep Grand Cherokee
4g67 head tourqe settings
Just to add to previous solution...
Assuming your head is straight & without defects, ensure you follow the correct tightening sequence diagram (see numbers) below:
Front of engine
i e
n 10 8 x
t h
a 4 6 a
k u
e 2 1 s
t
5 3
s s
i 7 9 i
d d
e e
1) Apply a small amount of engine oil to the thread section of the bolt and install so the chamfer of the washer faces upward.
2) In the proper tightening sequence (as shown above), torque bolts initially to 22 ft.lbs. (30Nm)
3) In the proper tightening sequence, now torque bolts to 45 ft.lbs. (61Nm)
4) In the proper tightening sequence, finally torque bolts to 68 ft.lbs. (92Nm)
Now you can Install the Camshaft sprocket and tighten it to 65 ft.lbs. (90Nm), while holding sprocket in place using the correct wrench.
Confirm proper timing mark alignment.
Cheers,
Aug 17, 2009 | 1991 Mitsubishi Galant
How to use tax buttons on victor 1208-2 calcutator
1. Slide the "Rate Set/Item/PRT/On/Off" switch to "Rate Set" position
2. Enter the rate value.
3. Slide the "Rate Set/Item/PRT/On/Off" switch to "PRT" position.
You can also dowload the instruction manual
Jul 26, 2009 | Victor 1208-2 Calculator
Cylinder head torque settings 1990 2.6L isuzu motor
From front to back is this:
7 3 1 5 9
8 4 2 6 10
First torque value is 58 ft lbs.....then final torgue is 72 ft lbs.
Mar 21, 2009 | 1990 Isuzu Spacecab
77 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
