Question about ASUS M2N-E Motherboard
No Output to monitor, no beeps, fans all OK
I have a brand new M2N-e board with brand new AMD Quad Core, new 2GB RAM, new GFX card
when i boot it just powers the fans up, the green MB light comes on but i get nothing else.
the monitor picks up a cable has been attatched so think the GFX card is OK
any ideas whats up?
  • karanda Mar 11, 2008
    thanks for that, i am running a 9500 Phenom, i have tried reseating the card and resetting the CMOS, how can i update my BIOS without being able to see the screen?
    President:
  • 2,351 Answers
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Posted on Mar 11, 2008
I have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one long then two short, with...
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
Feb 28, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
Got a A780L3L mobo,, AMD Athlon II X4 645 AM3, 4GB DDR3 1333MHZ and nothing else. will not boot. error beeps, 1 every 4-5 seconds. can you help please?
this beep mean A video error has occurred and the BIOS cannot intialize the video screen to display any additional information, check your monitor to VGA port??if all ok this mean
you need to place PCI VGA CARD for change your ON BOARD VGA card that was error
i hope this helpful
thank you for using fixya
Feb 03, 2011 | Biostar A780L3L AMD 760G Socket AM3 mATX...
No display or beeps, Tried everythin, and out of ideas
ok, you seem to have covered most of the normal trouble shooting procedures.. Now, you say it beeps when you take all the ram sticks out but does nothing when you fit ram. My first impression is that this is a ram issue. Maybe the ram is not compatible with the board or has been damaged. This can also be the case if the board itself is damaged. It could be that the i/o controller chip may have thrown in the towel and fitting ram causes the board to access this chip. No ram means control passes over to the BIOS error routines and the i/o chip is NOT accessed. Or, it could be both.. Try the ram sticks in another PC first. Static discharge damage is very common, even if you have the anti-static mats etc. I have mats, a wrist strap even my workbench is grounded along with my soldering station etc but I have still damaged boards through static discharge. I have also found that some brands of Ram simply do not work with certain boards so try the ram in another PC first !! Also, make sure that the ram you are using is correct and that you are NOT mixing different sizes or speeds. Next, make sure that non of the USB ports in the case are connected and that the boards own USB ports are not damaged as a bent pin in a port will always cause issues. Sorry that this may not be much help but as I said before, you are covering all the bases, the beeps without ram are making me lean towards a ram issue though..
Apr 02, 2010 | Asrock K8 Combo-Z Motherboard
Hey, I have a hp zd8000 netbook with an ati mobility radeon x600 128mb video card i would like to know if i can run cod4 on it thx.
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Jul 05, 2009 | Dell RADEON X600, (128 MB) Graphic Card
ASUS M2N-E SLi Motherboard No Graphics
I have the same board (M2N-SLI) with a BFG 9800 GTX with no video either. I have the card in the black slot and I have 2 mem sticks in the yellow. Shouldn't make a difference if I'm using a monitor not an LCD right? Everything spins up for me too, hard drive, vid card has power, CPU fan is on, post (green) light is on.
Sep 19, 2008 | ASUS M2N-E SLi Motherboard
P5k motherboard
remove the ram, do you hear beeps?
you might want to get your hands on one of these
http://cgi.ebay.com/New-8digit-PC-Motherboard-CPU-Ram-Analyzer-Test-Card_W0QQitemZ190231285206QQcmdZViewItem?IMSfp=TL0806211611r25031
if link broken click here
Reseing the bios shouldn't be a problem go ahead, or is there something I don't know? does it void the warranty? I don't think so.
Jun 23, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
My Computer does not boot
please check whre u have connected ur monitor comm cable, is it in agp card or on borad display card
Apr 21, 2008 | ASUS M2N-MX Motherboard
Brand new motherboard wont start up
try taking 1 stick of ram off the motherboard, and boot up with 1 stick in slot 1 or 2.
You should get some beeps, 1 is system Ok.
3 is usually RAM/Graphics problems.
Also try booting with the motherboard setup disk in the CD Drive, it may be looking for files to initialise the Board.
And the obvious, check that all cabling is correct from mainboard to front panel. Power on/off Reset et,c.
View the user manual to see if the board has any jumper/dip switch settings for different configurations.
Mike @ compurepair.
Mar 14, 2008 | Computers & Internet
ASUS M2N-E Motherboard Logo
220 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
