Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Posted on Mar 10, 2008
Motorola k1 problem
The predictive write mode in SMS messanges dont work the celular phone dont write any letter or word ? what can I do? Thanks in advance
  • lponcho Mar 28, 2008
    the problem with mimotokrzr k1 is that on the predictive mode on sms it doesnt matter how many times i try the phone will just not type anything "predicting" my word it would only work on extended tap mode wich i dont like because it takes to much to write a sms... please help me with this!!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
694
Points
Pressing the # key changes the entry modes:
Abc1 = single character
123 = numbers (of course :)
& = special characters
Abc2 = predictive text.
Hope that helps.
3helpful
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
How do you get the predictive text of a motorola krzr k1
on your krzr press the middle button menu/messages/new messages/new message/and toggle w/ the # key until you see "abc" ,now key 84265...okay you welcome
Motorola k1 will only send mms not sms messages
My phone is doing that, too!! It just started doing that the other day. It seemed to help for a little while if I restarted the phone, but now it won't send any sms messages at all, but instead sends them as mms.
I cannot remove predictive texting from my motorola razur. please explain how
ok mate go into to write a message now when you done that just go down and enter hello and then delete it and then press options and scroll down till you see predictive txt and click on that and turn it off and there you go hope this helps and also dont forget to rate me .
Motokrzr K1
your phone's text entry mode is currently set to 'predictive text' which means the phone is trying to 'guess' the word that you want. Teenagers find this easy to use and fast, but I, like you, absolutely hate it.
This mode is easily changed. When you start to write a text message, before entering any text press the 'hash' key (bottom right) sequentially until the top left of your display title bar shows 'Abc2' this means your phone is now in ordinary text entry mode.
You can also change the case (capitals etc) by sequentially pressing the 0 button (bottom centre).
Hope this helps
3answers
How do i remove predictive text
go to your messages... then choose message setting... look for default text input and just choose iTap (i think???) just play around with your message setting...
11helpful
4answers
Predictive text on a motorola w375
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
K1 motorola
there is a program called motoupdate you can search for it in google once you run the program it will automatically correct this problem
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
