Siemens 24 in. SL34A006UC Built-in Dishwasher
Problem for Siemens 24 in. SL34A006UC Built-in Dishwasher
Does not stop running
By broncos 50 on Mar 10, 2008
Hi, I have a siemens dishwasher. I have owned it for almost two years, and have never had a problem with it. I ran it last night before going to bed, and when i came downstairs this morning, it sounded like it was still running. I opened it, and there was a motor still running in the bottom of it. I turned it off and then back on and ran it for a cycle. When it was done, the motor was still running. Any ideas?
Same Problem
Sep 17, 2008
-   I have the same problem as this, but my dishwasher never starts the wash cycle. It drains the water and keeps running. -   silkes4
Solution #1
posted on Nov 19, 2008
Not Rated)
silkes4
Rank: Apprentice
Rating: 0%, 0 votes
I received this from GWOL... and it corrected my problem.
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Was this helpful?
Yes
No
Solution #2
Not Rated)
magpac2000
Rank: Apprentice
Rating: 0%, 0 votes
I had a problem with a clog in our garbage disposal drain pipe. The pipe was cleared up but subsequently the dishwasher is not functioning. When the door is opened and the on/off button is pushed the motor automatically starts running without a cycle being selected. Also, there doesn't seem to be any water getting into the washer. It is a siemens SL84A302UC-01 It was working perfectly the day before. Can you help me?
Thanks
Was this helpful?
Yes
No
Popular Solutions for Siemens 24 in. SL34A006UC
Questions and Unsolved Problems for Siemens 24 in. SL34A006UC
Do you recommend Siemens 24 in. SL34A006UC Built-in Dishwasher?
Answer
Answer
my dishwasher is stuck in the empty cycle and continues to try and empty even when all the water is... (More)
Answer
door on dishwasher is stuck in the open position and can not close to run cycle.
Answer
My siemens dishwasher stops at rinse cycle and water refuses to drain out
Answer
I took my diswasher apart to fix the door latch now because of the spring mechanism I am having a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Orlando, FL
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
