Question about ViewSonic VE175b 17" LCD Monitor
Viewsonic VE175b image breaks up
I have a Viewsonic VE175b. It's out of warranty. The problem I have with it is that after it has been on for a while, the image starts to break up with horizontal "static" lines. Then the image flickers on and off, eventually spending more time off than on. If I turn the thing off complete for a couple of hours, it will then operate fine for a couple of hours. But then the cycle begins again. Any ideas?
  • 1 more comment
  • Dewey3k Mar 11, 2008
    I opened the thing up and my admittedly casual inspection did not identify an obviously blown capacitor. There are a bunch of them however. Any suggestion as to whether it is financially worth it to have the thing repaired versus just buying a new one?
  • Dewey3k Mar 12, 2008
    As I said, no obvious bad capacitors. They all look fine to the eye. Guess i could put my voltmeter across each one. Don't really have the time. Thanks anyway.
  • DonovanT Apr 16, 2008
    My ViewSonic VE175b does not power on, any idea what's wrong?
  • 47 Answers
A capacitor is busted have it repair
Posted on Mar 11, 2008
  • Darrel Barde
    Darrel Barde Mar 12, 2008
    to detect a capacitor is busted just look on top of the capacitor if
    you see a bulge on it thats defective.
    you can save a lot if you have it repaired than buying a new one
    but it is good to have a brand new one because you can assure the quality.
    Its your choice my freind
Replacement of backlight
Backlights themselves are not serviceable. Better to just buy a new unit if the backlight is bad.
May 15, 2014 | ViewSonic VE175b 17" LCD Monitor
Windows 7 compatibility
This monitor should be compatible with Windows 7. Just plug the monitor to your computer and let Windows automaticaly install the driver for it. No need to install the driver from the cd that came with the monitor.
May 20, 2011 | ViewSonic VE175b 17" LCD Monitor
ViewSonic VE155b
this means that your computer is set to either a too high frequency or too high resolution. Try to lower the resolution setting of your desktop step by step, until the message disappears.
Jul 23, 2010 | ViewSonic VE175b 17" LCD Monitor
I have a Viewsonic VE175b that is having back-light problems. Sometimes it takes up to 30 minutes for the backlight to turn on. Sometimes playing with the On/Off switch fixes the problem. To me it sounds...
yes power supply failing. you need to open it and look for leaking capacitors or crwoned ones. desolder the bad ones and take to a parts shop to get new ones and replace.
Dec 24, 2009 | ViewSonic VE175b 17" LCD Monitor
Viewsonic VE175b
That issue sounds familiar. Some DELL displays have exactly the same problem, and, for some reason, the model of your display reminders me the 172Fbp model that I'm talking about.
I believe the problem that you are having with your display is caused by a short circuit inside the display, as the power supply detects the short circuit, it stops working. You may need to get a technician to have your display repaired.
If you want to know more information about this issue, here is the link with a similar problem: http://josepino.com/?howto-repair-dell
Good luck !
Sep 06, 2009 | ViewSonic VE175b 17" LCD Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
VE175b 17" LCD No power.
Do you live on the second storey or higher? Couldn't resist. =)
It will probably be the capacitors on the main powerboard inside the monitor. Its a common fault with these and is easy to get repaired.
Unless you have fairly good electronics knowledge though you are best to take it to your local TV repair shop. The voltage inside reaches points far higher then even what you have in the wall sockets of your home.
The repair should not be expensive in any case. Call around and get a few quotes, also check who will service an LCD in your area, some will some wont.
Hope that helps =)
Apr 16, 2008 | ViewSonic VE175b 17" LCD Monitor
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
ViewSonic VE175b 17" LCD Monitor Logo
140 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
