Speaker Problem Thanks in advance. I plugged in some external speakers, then unplugged and plugged back in... within some 10 seconds. The external speakers worked fine, but after restarting my computer, I noticed the internal speakers stopped working. I ran the computer through "restore" to a time I knew the speakers worked, but... no dice. The internal speakers don't function. The external and headphones work fine. Help! Paavo.
  • 34 Answers
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Posted on Mar 10, 2008
I have no sound coming from the internal speaker,if i plug in a external speaker the external speaker works but when its unplugged still no sound from internal speaker.
Check your device and see if it's plugged into the system by hitting the right side of your mouse on the speaker symbol. It will let you see the name of the speakers in your computer. It should also tell you if there's a problem.
Feb 27, 2018 | The Computers & Internet
No sound on tv seiki 40 in
Hello
Sometimes, someone accidentally turns off the sound - check your settings and if you have external speakers, unplug them, switch off your TV and unplug everything, wait for 10 seconds and then plug it back in and restart it to check if this makes a difference; try some external speakers as well if they are available to you. Still nothing, call the manufacturer's helpline.
ilona
Aug 02, 2017 | Seiki Televison & Video
I have sony radio model no STK-KM22 it display flashing protector messege and I cant play any thing ,how I can solve thi ploblem?
Unplug for 30 seconds unplug speaker cords.twist all wire ends together tightly for each set of wires.one little wire not twisted tightly with the rest can short out throwing receiver into surgery protection mode.plug receiver back in or reconnect it.test each wire set to see if external speaker wire issue.wire sets are twisted good you will know as each speaker will come back on.twistem tight soldier them or use liquid tape to keep connection working properly.use surge protector to protect unit receiver.
Apr 09, 2017 | Sony Audio Players & Recorders
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
On my Kenwood vr-505 Under the speaker symbol it says clip and there is no sound coming from the speakers
Hello. My name is Dave. Unplug the receiver. Plug it back in. When you first push the power button, you should hear one relay click. Within about 5 seconds, you should hear another click. My guess is, you don't hear the second click. Am I correct?
Dave
Sep 30, 2012 | Audio Players & Recorders
Hi , Im trying to make my external volume controler work om my Aer 4520. Its a litlle ring that puts volume up and donwn
Ebv65,
External speakers for your laptop are very easy to hook up. They should plug right in to the external speaker outlet on the laptop. Your acer 4520 has a Headphone/speaker/line-out jack with S/PDIF support. First you need to check all your volume levels within the control panel (located in the sounds and devices folder) to make sure they are up. This solve your problem. Thanks for visiting Fixya.com. Have a great day.
techguy21
May 28, 2011 | Acer Aspire 4520-5582 Notebook
Hi, I have a cobra 29 ltd classic, the audio worked fine, so far not eacuchò, you connect the external speaker and had audio and the audio disappeared suddenly. please can you help me, thanks.
Hi, my name is John. Welcome to FixYa. unplug the external speaker and try it, then plug it back in and see what happens. Keep on plugging it in and out, could be sticking, let me know how it goes. Thanks for choosing FixYa.....John
Nov 29, 2010 | Cobra 29 LTD CB Radio
No sound from speaker, but works with external speaker plugged in
It sounds to me like you have blown the internal speaker.
Jun 17, 2009 | Music
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
195 people viewed this question
 Grubhead
Grubhead
