Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
Hi
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Many Thanks
  • 1 more comment
  • Anonymous Mar 21, 2014
    When you add a second tray you get error message and printer doesn't run on the panel on the printer it shows ! In orange light and diamond in shape button is light in green
  • Anonymous Mar 30, 2014
    Button C flashing orange
  • Anonymous Apr 01, 2014
    will not print
Posted on Mar 12, 2008
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
I keep getting message that my Canon Printer Pixma iP3000 'is offline'. How do I get it to be 'online' so it can proceed to print the 2 documenys on the printing queue?
Here's the steps in order for you to get your printer ONLINE and be able to print.
1. Click on your START menu
2. SETTINGS / Printers and FAXES or via COTNROL PANEL, printers and faxes
3. RIGHT click on your printer
4. Make sure "Use Printer Offline" is NOT ticked, if it is, UNtick it
Your printer should respond immediately if there are documents on queue for printing and should print it out.
Hope this helps!
Good Luck!
Mar 14, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon printer IP3000 5 lights flashing
If its just orange led flashing .. You need to replace the print head..
if its cycling 5 times between orange and green than there is a problem with the ASF cam sensor (which means paper feed unit)
Mar 30, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
PIXMA Ip3000 with one orange and one green flash error
Hi may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Oct 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Pixma ip3000 printhead won t come out of docking station
Perform a EEPROM reset:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
S9000 printer will not print.
Hi
Try this see if work for you.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Jan 13, 2009 | Canon i950 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,050 people viewed this question
old marine
old marine
