30'LCD Monitor/TV seperate power box and seprate control unit
Monitor powers on and screen flashes on but right back off with power staying on.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 52 Answers
May or may not help, but try pressing the "source" button, after turning it on..
Posted on Mar 11, 2008
My tv is on but the standby button keeps flashing and I cannot do anything with the remote either I've unplugged it and left if for 30 mins
What make and model of TV is this? If its a LCD tv thats more then a few years old chances are its the very common problem of failing capacitors in the power supply. That will usually cause the issue your describing. I have rebuilt dozens of tv power supplies now, the term commonly referred to now is re-capping the power supply. The capacitors become leaky and the voltages go out of tolerance and the tv will no longer turn on. If you can find someone to take it apart and check the power supply board inside that would be your best bet, otherwise its time for a new tv otherwise. There is no simple fix other then repair unfortunately.
May 04, 2017 | Televison & Video
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Oct 01, 2010 | Akai LCT3285TA 32 in. LCD Television
47LG70 - PICTURE WENT OUT. STILL HAVE SOUND. HEARD A POPPING NOISE WHEN PICTURE WENT. TV IS ONLY 1 1/2 YEARS OLD. ANY IDEAS WHAT MAY OF HAPPENED.
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
Sep 21, 2010 | LG 47LG70 42 in. LCD TV
Tv little green light is blinking but tv won't power on
Ur tv power supply board it dead.The power supply board,that the board the a/c power coard go into it,that ur tv power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replament.
May 26, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Problems with Dell E176FP 17" LCD Monitor?
Kindly disconnect the monitor from the computer and power it on , if the screen is still blurry on the self test feature check , the monitor is bad.
You can press the menu button on the monitor and select Restore to Factory setting or Factory reset option. If the problem persists you can call LCD repair
http://www.lcdrepair.us/
Monday to Friday: 8:30 am to 4:30 pm
Central Standard Time
Phone :
469-521-7517
If you have purchased,the dell monitor seprately from the computer, it carries a three year replacement warranty.
Thanks
proton
Nov 21, 2008 | Dell E176FP 17" LCD Monitor
No composite input signal
`Hi,
If the monitor is making the noise , the monitor circuit baord has gone bad.
If you have purchased the monitor on a seprate order from dell it would be covered under 3 yr warranty. If the same has been bought with the Dell computer , it would hold the computer warranty. would request you call the manufacturer.
Before you call Dell , you can try the following things
1. Disconnect call cables from the back of the montior
2. Press the power button a couple of times in the front of the monitor to drain any resident charge
3. Reconnect the power cable
4. check if you see the monitor self test running and if the noise is still there with there
Thanks
Proton
Oct 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
SDM-HS73P Screen Flashes
This is a problem I have seen with a few LG monitors.
Your Inverter circuit is fine (that powers the lights to your screen so you can see the image on the LCD panel) but the monitor does not like having a video signal attached to it.
  1. Bad capacitors on the power board can upset the current going to the controller board. This board included the video input circuit and the power supply needs to be stable for this to operate.
  2. The controller IC that translates the video signal into what the LCD panel controller can understand is failing. Normally this fault occurs in the horizontal and vertical input of the IC. The fact you can see the other message on screen is due to it going through it's own internal and seperate section of the IC. In this case the only repair option is to replace the internal video board. Sony will not supply the parts directly to the public, but if you are really nice, they "may" tell you where to get one externally to Sony.
Hope that helps =)
Apr 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
