Question about Microwave Ovens
Infrared toast My new infrared oven - Speed toast only browns one side
  • marycwhit Mar 10, 2008
    Bottom element not heating at all
  • 833 Answers
Is the element glowing on the other side? Is the unit being used correctly ie, the correct toast setting versus 'top brown'?
Posted on Mar 10, 2008
  • Robert Hirst Mar 10, 2008
    Okay, then if you are using the toaster feature and it means toast both sides...then the element might be bad. In some places, toast means top brown. Clarify that and then take appropriate action.
What does F01 Code mean
I couldn't find the answer on the Miele web site, but here is a link to their contact page:
Contact Us
Nov 08, 2014 | Miele Classic Design H4084BMSS 24" Speed...
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
We left our microwave oven outside in the rain. Can it be used after getting wet..?
NO, is very dangerous to due the parts for high voltage component like the capacitor and magnetron , I recommend to dry the microwave using Lamp infrared red by 36 hours. very well.and test again.God bless you2ed30750-be4a-4446-94a2-568660cdb1b6.gif
Apr 04, 2013 | Microwave Ovens
Heathware infrared oven broke
Remember use the DVOM. First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Microwave Ovens
Microwave Fried
Unless a expensive unit I would replace it as the main power supply for the unit a who knows what else got toasted---
Aug 27, 2012 | Microwave Ovens
Whirlpool ukm120 microwave stopped working
1) you use contacts cleaner with very speed dry or isopropyl alochol to 100% for dry the humidity sector inside from microwave.+power cord+main switch. The reason is has humidity. This water or some other liquid are NOT that reason isolated. See if some parts are burned or smell strange.
2) test the fuse again. 3) dry the HV transformer and magnetron with infrared LAMPS by 8-10 hours for to dry any humidity.
3) and try again.see the inside of microwave
Jul 26, 2012 | Microwave Ovens
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
Loud pop with smoke
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from
May 23, 2008 | Emerson MW8107WA Microwave Oven
Oven burner
For service assistance and the location of the nearest Samsung service center, please call 1-800-SAMSUNG (1-800-726-7864), or go on-line to http:WWW.SAMSUNGSUPPORT.COM
Oct 25, 2007 | Samsung MT1066SS Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
