Question about Canon PowerShot A400 Digital Camera
E18 I recently dropped my cannon a400. the lens goes out and in but problem says e18 still
    Problem Solver:
  • 6 Answers
More information can be found on the following site to attempt to
repair the E18 Error.
http://www.e18error.com/repair.html
Miller Photography
www.millerphoto.ca
Posted on Mar 18, 2010
  • 172 Answers
Lens Drum gear broken so that it flash E:18,it need to replace
SOURCE:
Cannon Powershot A400: Camera is not starting at all after using a fully charged chargeable batteries. the lens comes out a little as we power on and thats it, the screen is blank and there is no response...
These cameras invariably employ and metal worm against a nylon cog to move the lens barrel in and out. If dropped on the barrel while open, or the barrel is pressed, the nylon cog is ripped against the worm. There is no longer a smooth spiral for the cog to run on.
Not being funny but, its a fairly old camera with a low picture resolution, I would suggest its probably not worth repairing. Time for a new one.
Apr 06, 2011 | Canon PowerShot A400 Digital Camera
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
E18
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 11, 2010 | Canon PowerShot A400 Digital Camera
I am facing e18 problem.Need to open a400 camera.Tell me the steps.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try. And for the A400, have actually had a lot of success with these, especially Fix #7.
Jan 31, 2010 | Canon PowerShot A400 Digital Camera
Turns off when trying to take photos and E18 comes
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 14, 2009 | Canon PowerShot A400 Digital Camera
I have a cannon powershot a 85 it was working fine then nothing i turn it on and it lights up the cannon sign then goes of. it is showing E18 in bottom legt hand corner. i have tried both rechargable and...
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
E18 Error
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
Feb 11, 2009 | Canon PowerShot A400 Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
Lens won't retract
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed two A400 cameras with this problem by using these methods:
Oct 05, 2007 | Canon PowerShot A400 Digital Camera
Canon PowerShot A400 Digital Camera Logo
160 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
