Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Prodigy Electric Dryer not getting hot
Any idea why it's not getting hot? I noticed that the exhaust hose in the had come undone. I read somewhere here about dust on the heating element or a fuse?
  • sargetpd Oct 20, 2008
    my dryer is running fine. But does not get hot. I checked the lint trap,exhaust hose,both are clean
  • 55 Answers
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Posted on Mar 10, 2008
Ge dryer way too hot. I have cleaned all the lint out but still way too hot. unplugged vent hose and ran machine still too hot. Took apart machine and tested continuity of heating element and its fine....
I do not know your definition of "way too hot". Remove the exhaust vent and insert a accurate thermometer in the dryer exhaust. Run the dryer on high heat. The temperature should get up to 165 degrees then cool down to about 125 degrees then back up to 165.
If it goes above 165 and stays there replace the high limit thermostat.
If it cycles correctly it is OK.
Aug 31, 2011 | GE DWSR405EBWW Electric Dryer
MY DRYER IS NOT GETTING HOT IN THE INSIDE BUT THE OUTER BACK SIDE OF THE DRYER IS
Is your drum turning? Sounds like blower has stopped working. Or vent is plugged.
Lets check blower. Remove big exhaust hose. Now see if air is blowing out hard. DON'T put your hand in hole. If air is flowing blower is okay. So check the hose may need cleaned. Hopefully Hose is blocked.
Always unplug before removing any covers.
May 17, 2010 | GE DVL223EBWW Electric Dryer
GE DWSR463EGWW electric dryer takes forever to dry clothes. Heating element comes on but then goes off. Where do I locate the thermal fuse if that is the problem.
The thermal fuse only shuts off the elements if the proper air flow isn't acheived. If the clothes are hot but still damp after the drying cycle then you have a blockage in the dryer exhaust either at the hose at the back of the machine or in the lint filter area. Check both and clean and your problem should be solved.
Hope this helped you
Dave
Jan 14, 2010 | GE DWSR463EGWW Electric Dryer
Dryer blows hot air and tumbles; but condensation builds on door and clothes don't dry
SOUNDS LIKE YOU HAVE AN EXHAUST PROBLEM LIKE THERE MUST BE SOME KIND OF RESTRICTION
Dec 16, 2009 | GE Profile Prodigy DPSR513GA Dryer
The dryer is not drying the clothes. It takes two
Take you vent off and remove the restrictions. How about a few repair pix?
Sep 25, 2009 | GE Profile Prodigy DPSR513GA Dryer
No heat from GE electric Dryer
Possible. Here are all of the reasons why you might not be getting heat. Read them over and get back.
Jun 07, 2009 | Dryers
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
338 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
